85 AT transmision problem
Was driving the car yesterday, went to leave from a stop, put my foot into the gas pedal pretty hard. It started out ok, then when it came to the 1-2 shift, it was like the transmission was not there. It revved to the moon, so I let off the gas, it then shifted into 2nd very hard. Now it will not go into 4th. If I try to make it go into 4th, nothing happens. I can put it into the 3rd position on the selector, or I can do a manual shift using, 1,2 then 3 and it works fine. Also, if I go from the 3 position to the 4th position on the selector, it feels like I put some extra drag on it, the car will start slowing down a bit. Can put it back into 3 and the feeling goes away.
Anyone know what the problem might be?
Also, does not feel like the lock-up is working either.
