how fast pressure drop for leaking injectors?
Old Oct 23, 2006 | 07:52 AM
Arlon's Avatar
Arlon
Default how fast pressure drop for leaking injectors?
Checked pressure and was fine but leaked down to 20 lbs in about 15 minutes? How fast will acceptable injectors leak down pressure?
Old Oct 23, 2006 | 08:33 AM
Wheelman's Avatar
Wheelman
Well, does your car start / run ok? If so then I guess they are acceptable. As far as how your fuel system SHOULD work, it should hold at around 40psi or so for about 30 minutes.
Old Oct 23, 2006 | 08:40 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
You have to rule out the other areas of pressure loss before you can call it an injector leakdown problem. Could be the check valve in pump, dampner above fuel pump or fuel reg also.
My pressure loss was at the dampner. I removed it and replaced it with 2 clamps and a piece of hose.
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
Old Oct 23, 2006 | 08:49 AM
Bob CTS's Avatar
Bob CTS
Follow the procedure to rull out other components.
Old Oct 23, 2006 | 09:05 AM
redrose's Avatar
redrose
like agent86 sez.
should hold 10 psi after 24 hours to run ok (my experiences) ...some hold much better
Old Oct 23, 2006 | 09:27 AM
Arlon's Avatar
Arlon
Starts fine but runs fair. It seems to have a fairly dead #2 cyl. Has spark but the plug in that hole was wet and much crudier than the other 7. I am assuming a leaking injector in that hole. Definately will not hold 10lbs for 24hrs. More like an hr. at best.. Just got some ford injectors from ebay I think I'll try and see how they do... agent86, thanks for the manual link.. Arlon
Old Oct 23, 2006 | 09:58 AM
USAsOnlyWay's Avatar
USAsOnlyWay
I have a bad check valve in the pump, made me crap myself the first time I did the pressure check. But the car runs great.
Old Oct 23, 2006 | 10:18 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Too fast but as others said rule out other things first
Old Oct 23, 2006 | 10:30 AM
wro87's Avatar
wro87
If you have the FM has lots of info check it out so you can see about pinching off the return line for leakage. But it sounds like you may have spotted the bad injector if the plug is real wet. Check your oil for contamination from excess fuel. You may want to change it.
wro87
Old Oct 23, 2006 | 11:14 AM
mikey whipreck's Avatar
mikey whipreck
I'd like to point out that, that is within spec of my '85's FSM.
To how fast pressure drop for leaking injectors?
