406 Guys - Step inside
Old Oct 23, 2006 | 04:09 PM
black_89_vette's Avatar
black_89_vette
Default 406 Guys - Step inside
I'm currently running a 383 and due to me being stupid last year and not checking antifreeze level enough, the block actually cracked.
Yes, I ran all this year with a cracked block. But my mechanic said it was an external crack by the knock sensor and no oil in antifreeze or vice versa. I guess I got somewhat lucky there. Why the frost plugs didn't just blow out, is beyond me.
Anyways, over the winter here I'll be replacing the block and checking the interals (although I'm sure they're fine) and maybe changing the cam for someting more aggressive since it's been 5 years on current cam.
My question here is, if I want a 406 block, are these available in 1 pc. rear main seals? If so it must be aftermarket blocks and how expensive would that be?
Would I have to get a retro roller fit cam kit for it if I can only get a 2 pc rear main seal?
Thanks,
Jerry
Old Oct 23, 2006 | 05:10 PM
88BlackZ-51's Avatar
88BlackZ-51
nice to know info jerry. i dont know why more guys dont build 406's.
Old Oct 23, 2006 | 05:22 PM
black_89_vette
And to these guys who do run the 406's , what kind of power are you making and with what mods?
***EDIT***
Hey Rick, changed my av buddy. That nicer looking black C4 behind yours is mine.
Old Oct 23, 2006 | 05:56 PM
cv67's Avatar
cv67
St. Jude Donor '05
All 406s are two piece mains, use a retrofit roller. You can buy a 1 piece adapter through Summit or Jegs. C.A.T. sells the lifters for $152
..Doesnt have to be expensive.
Dont know if the aftermarket blocks (Dart) are 1 or 2 piece.
Old Oct 23, 2006 | 06:23 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
2 piece on the aftermarket on dart and merlins i do believe there is a bowtie block that is 1 piece here
http://www.sdpc2000.com/catalog/593/...-Tie-Block.htm
Old Oct 23, 2006 | 09:04 PM
USAsOnlyWay's Avatar
USAsOnlyWay
I'll still think you are wrong about the lifters, but if you have them in hand then
Otherwise I am sticking with what the guy who called said, type. They are roller solids.
Old Oct 23, 2006 | 10:30 PM
bjankuski's Avatar
bjankuski
***EDIT***
Mods and power are in my sig for the 406.
No 400 blocks cam from the factory with one piece seals but I do not know about all the aftermarket combinations, maybe one of them has what you are looking for.
Old Oct 23, 2006 | 10:53 PM
zelement's Avatar
zelement
Dart 400 block here with 2pc. If you want to stay hydraulic roller you have to put in the retrofit hyd. roller lifters, they are very expensive.
I would just go solid roller.
Old Oct 23, 2006 | 11:42 PM
black_89_vette
So if I went solid roller, I wouldn't need a retro roller fit cam kit?
Old Oct 23, 2006 | 11:58 PM
sami85L98's Avatar
sami85L98
If i were u and decided to go 406 than i would have seriously consider dart Little M iron block, will bare block cost u alone is 2200-2500 range, than rotating assembly and consider a big roller cam not the solid roller though its not streetable and u have to adjust valve train every few thousand miles, solid roller cams will eat valve train alive, they are good for pure racing. Intake is ur choice either SR or Mini ram either way it will be torquish. when it comes to heads i will seriously consider Brodix 200c RaceRite. Also when it comes to Rotating assembly consider either Callies or Crower (if u can afford) and SRP or JE pistons, compression in 10.7-12:1 range and with a good tune, it will be easily close to 500 Rwhp. Check Shafiroff.com. sami.
Old Oct 24, 2006 | 08:29 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
YOu definately want to go aftermarket with the block, unless you can land a 509 casted 400 block. The 509 casted blocks were the best ones to get...anything else your playing with fire. Two bolt mains also, but the 509 casting will have that....
However if you want the creme of the crop, get a dart little M block....after running my 406 motor, which went and held up great, you can't believe the difference the aftermarket blocks provide.
Shop around you can get some pretty good deals, or you can get in touch with me and I can hook you up with some good deals...
Old Oct 24, 2006 | 09:26 AM
88BlackZ-51
jesse, what mods did u have with your 406? and how did it run?
Old Oct 24, 2006 | 10:19 AM
cv67's Avatar
cv67
St. Jude Donor '05
Dont be afraid of a solid roller, with the good locks/rocker systems out you harldy have to touch the valvetrain.
Lifters have come a long way, also.
Look into the Crower sever duty ones (they are durable as hell) or the new Iskys . Not really crazy about the Comp SR lifters.
Old Oct 24, 2006 | 09:45 PM
AKS Racing's Avatar
AKS Racing
I have been running a Comp large SR on the street since '01 in my 408. These cams can be made to run with minimal maintenance. SR cams have come a long way in the last 15 years.
Aaron
Old Oct 25, 2006 | 03:59 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
IF you look in my signiture is basically will walk you right through the assembly of my 406 motor. All the parts should be spelled right out which were not anything real special - just the right ones to make the combination work. Quickest it went was 11.0X @123MPH....but knowing what I know now about my cars suspenion and getting it to launch like it does now...it would easily go 10.7-8s.
Hope this helps and If you need any help with the tuning of the beast buildup - just let me know...
To 406 Guys - Step inside
