Tips For Removing Power Steering Bracket For LT-1
Old Sep 18, 2001 | 02:05 PM
ce_me_vette's Avatar
ce_me_vette
Default Tips For Removing Power Steering Bracket For LT-1
I needs tips and pointers for removing the power steering bracket for an LT-1 engine. I have the Helms service manual for my car.
Is removing the power steering pulley required?
If so is there another way to remove/install the power steering pulley beside using the special J-series tools specified in the Helms manual.
Is removing the serpantine belt tensioner required?
Is removing the idler pulley required?
Thanks for any help you can give me guys.
Old Sep 18, 2001 | 04:17 PM
Dave's_88's Avatar
Dave's_88
Default Re: Tips For Removing Power Steering Bracket For LT-1 (ce_me_vette)
This probably won't help....I have an L98 :rolleyes:
But, after 2.5 hours, you probably want an answer.
I had to remove the power steering pump pulley to get to the bracket holding the pump to the block. To remove the pulley I disconnected the serpentine belt, and used a pulley puller ($30.00 from Autozone) to remove the pulley. There were 8 bolts holding the bracket on (4 to the block, 4 to the front of the pump).
I hope the LT1 is set up similar to this....probably not.
Good luck,
Dave
Old Sep 18, 2001 | 05:53 PM
ce_me_vette
Default Re: Tips For Removing Power Steering Bracket For LT-1 (Dave's_88)
Thanks for the reply. Is this pulley puller from Autozone a standard size part and can I use it to install the pulley back on the power steering pump?
Old Sep 18, 2001 | 07:54 PM
mikey's Avatar
mikey
you do not need to remove the p/s pulley if you just pull the pump itself off.. idler pulley assembly can stay on until after it's out of the car if you want.. set a/c compressor up on driver wheel well lip without disconnecting the a/c lines to it.
the p/s pump has to come off because there is a bolt behind it attaching the big bracket to the engine.. but you can remove the pump without removing the pulley by sticking a socket/extension thru the slots on the pulley.
have fun,
mikey
Old Sep 19, 2001 | 11:56 AM
ce_me_vette
Default Re: Tips For Removing Power Steering Bracket For LT-1 (mikey)
Thanks for that tip mikey. Any ideal on what size socket is need to remove the power steering pump.
Old Sep 19, 2001 | 02:56 PM
mikey's Avatar
mikey
can't remember.. something in the 9/16" range..
you know chevy engines.. it's either 1/2", 9/16" or 5/8" or it's not an original bolt *ha ha*
Old Sep 20, 2001 | 01:40 AM
381 WS6's Avatar
381 WS6
4th Gear
The two bolts holding my PS pump on were 10mm (F-body LT1). You'll need a short extention.
Old Sep 20, 2001 | 04:03 PM
ce_me_vette
Default Re: Tips For Removing Power Steering Bracket For LT-1 (381 WS6)
Thanks 381_WS6. I knew it was metric just wanted to confirm the size. This will save me a little time :D
To Tips For Removing Power Steering Bracket For LT-1
