Replacing battery cables
Old Oct 23, 2006 | 08:45 PM
mk842766's Avatar
mk842766
Default Replacing battery cables
I need to replace the battery cables on my 85...any handy tips on the easiest way to get this done??
Cheers,
Michael
Old Oct 23, 2006 | 08:54 PM
C4396roadster's Avatar
C4396roadster
good luck
Im sure its no big deal I thought about it and changed my mind,got lazy I bought cables fm autozone 2ga pretty cheap
Im sure someone who has will chime in
Alan
Old Oct 23, 2006 | 09:00 PM
bogus's Avatar
bogus
I have a complete set from my wifes 1987... in very good condition. if you want them, lemme know.
Old Oct 23, 2006 | 09:30 PM
C4boy's Avatar
C4boy
Good Luck!!
It's just one of those pain in the butt jobs. If your 85 is the same as my 86, the positive cable goes around the back of the intake and you have to be carfeul not to take out any other wires by accident. Pull the distributor cap, first. There are a couple clamps/guides that keep the + cable in place. There is one off the brake booster, another near the oil dipstick.
For the negative cable, you may have to remove the windshield wiper motor to make more room. The ground attaches behind the head or on a tranny bolt somewhere. I haven't done that one.
Old Oct 23, 2006 | 10:05 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Bud, if you still have the set and nobody wants them, i could use them for my 87.. Let me know...
vinnies87
Old Oct 23, 2006 | 10:10 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
I did this last year on my 94. The positive cable was oxidized down through the cable for at least 18" and I was getting poor connection. I bought the GM cables from the local Stealership and did this PITA job myself. It is not hard, but just difficult to see where you need to thread the cable. I wound up cutting the old one in the middle and pulling the end connected to the starter out through the bottom of the car and the battery end out from the top. Threading the new one in was the tricky part. I used a number of Mcguiver looking tools to thread the new cable beind the intake and over the transmission while keeping it away from hot engine stuff and keeping it from snagging and tearing good cables out.
Just take your time and it will thread through.
Good Luck
Old Oct 24, 2006 | 07:21 AM
mk842766's Avatar
mk842766
Thanx, guys....need to get this done, and hopefully it will clear up my no-start condition.....
Old Oct 24, 2006 | 03:41 PM
Aaron's 87's Avatar
Aaron's 87
run a search - I had a couple topics about this a couple months ago. Lots of good info in them.
In my experience with the positive, bend the starter end straight, tie good twine to the end, and pull it out carefully from the battery compartment twisting when it resists. Tie the twine that is now routed through your engine compartment to the new cable and pull it back through carefully. This is much easier with two people - one to pull and one to twist.
Old Oct 24, 2006 | 05:24 PM
mk842766's Avatar
mk842766
Yep...that's what I had thought I would do....didn't want to drop the tranny just to replace the cable...
To Replacing battery cables
