EGR test, how to?
Old Oct 24, 2006 | 02:38 PM
LORDZ's Avatar
LORDZ
2nd Gear
Default EGR test, how to?
Working on an 89 vette, 25k miles. I have the upper plenum off whle adding an afpr and found the previous owner disconnected the egr valve. I have a mighty vac, I bring it to 15 in of vac and it slowly bleeds off. Should it hold or bleed off. Any other reason why it would be disconnected, solenoid or temp switch or most likely the valve. Any way to test while apart? I searched but couldn't find the egr test specifics IE how much vac and how long. Thanks
Old Oct 24, 2006 | 02:40 PM
mikey whipreck's Avatar
mikey whipreck
You can easily test the whole EGR system, but you'll need the FSM flow chart to test it properly.
If you contact Agent86 and ask nicely, maybe he can help you out with that.
EDIT::: Did a search and found this... http://forums.corvetteforum.com/show...&highlight=EGR
Old Oct 24, 2006 | 03:55 PM
LORDZ's Avatar
LORDZ
2nd Gear
One of the links in that forum has it, Thanks
To EGR test, how to?
