studder problem
Old Sep 18, 2001 | 05:46 PM
fastrob's Avatar
fastrob
Default studder problem
my car studders a little when i take off a little slow but if i get on it a little it stops just instaled a new fuel pump ,fuel relay,fuel fillter any sugestions :smash:
Old Sep 18, 2001 | 08:39 PM
White91's Avatar
White91
Default Re: studder problem (fastrob)
Check your throttle position sensor there is probably a dead spot in it. It is just a variable resistor so take it off get an ohm meter preferably analog and see if the resistance changes smoothly as you move the arm on the sensor.
