Altitude - Air Density - TPI Intake???
Now, I live, and spend most of my time at 5500 ft. I am thinking of the logistics on my TPI Corvette intake. So here I am with fuel injection, that has no problems at this altitude. However, Air is a different story. I would logically assume, that larger intake runners, Ported Plenum, and big throated bottom. Would benefit me more than most. The question is, and can I assume, that a 52mm TB would be advantagious? Even though I am not going with heavy mods. Mostly intake, and exhaust. perhaps 1.6 Rollor Rockers, at least on the intake would be advantagious as well. Also, it is claimed that you should increase your initial timing 1/2* per 1000ft. There is even a chart up here at the local college auto mechanics training shop that states the same thing. I power timed my Camaro years ago, on the dyno. It ended up at 23* adv. lead in at crank.
Just thought I would get some of you guru's to give me your oppinions, as this is not something that is brought up very often... Thanks
Amazing how much differently my car runs at sea level, I'm heading back to Florida for the holidays and can't wait to see how the mods so far run there.
The lower octane gasoline is a reflection of the lower combustion pressures possible with the less dense air. I have experimented with my car at the race track, and I have my base timing set at 14° BTDC. It seems to run the quickest and it doesn't ping or knock. You might experiment and see what works best for you.
RACE ON!!!
I've got to get the air out once it's in, and I have all the stock exhaust that come with my 88 main cats, pre-cats, and stock headers. Interesting, I guess everybody else in this area are sucking the same air. So that evens the competition up a little...
There was a form of forced induction that always intrigued me, with some piston singles, I think some of the Lycomings in the Beech Bonanza models had an STC (Supplemental Type Certificate) for turbo normalizing. It was a turbo but all it did was normalize the induction to sea level performance, regardless of altitude. The advantage, as I understood it, was that the lower boost didn't lower the TBO (Time Before Overhaul) on the engine, but you could be at say, 15,000' and the the engine would perform as though you were flying at or near sea level. I can't remember much about it though, might be mistaken about the boost, it might have been significant boost to duplicate sea level pressure @ 15,000 for instance.
I moved from Layton, UT, down here to NC about 2 years ago. My car picked up .7 and 5 MPH the first time I went down the track. Utah sucks man.
The State does have a few good qualitys, I guess... The Best of Corvette for Corvette Enthusiasts
