Painting Calipers
Old Oct 25, 2006 | 08:06 PM
SpeedRacerGirl's Avatar
SpeedRacerGirl
From: Hudson Valley Region, NY The "sonoma/napa" of the Northeast~~~~~ Are we there yet?
St. Jude Donor '08
Default Painting Calipers
Help.. I want to paint the calipers on my 93 to match the body color (bright aqua)
I know that there are some kits out there that come with high heat paint to paint calipers but they usually only come in red, black, blue, yellow, and white... just a thought.. but the car isnt driven as a daily driver.. you think painting them with touch up paint would hold???
Any thought appreciated.. thanks
Old Oct 25, 2006 | 08:21 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
I have found that Rustoleum makes several colors of high heat gloss spray paint that works real well. I just did my rear calipers in gloss black to match my GS calipers up front. I had the old calipers painted with the same stuff for several years, but only in red, with no flaking or major discoloring. This stuff is cheaper and actually works better than some of those kits. I had a couple friends that used a kit from Mid-America with not so good results.
I bought some painters masking tape and painters masking paper and covered and masked everything carefully to avoid overspray and it turned out real well. Also aluminium foil comes in handy as a masking aid too.
PS - the black Rustoleum looks great on the LT1 exhaust tips too.
Good Luck
Old Oct 25, 2006 | 08:24 PM
SpeedRacerGirl
St. Jude Donor '08
Originally Posted by biggrizzly
I have found that Rustoleum makes several colors of high heat gloss spray paint that works real well. I just did my rear calipers in gloss black to match my GS calipers up front. I had the old calipers painted with the same stuff for several years, but only in red, with no flaking or major discoloring. This stuff is cheaper and actually works.
Good Luck
Thanks for the advice... a few years back I used a kit by some company called G2 to paint the calipers on my ford SVT and they came out HOT!!! But I painted them red.. and well red doesnt go with a bright aqua vette... I was thinking white but that is just going to get gull of brake dust and nasty fast...
Old Oct 25, 2006 | 08:26 PM
biggrizzly's Avatar
biggrizzly
If you can't find the aqua color, black or silver is going to be your best bet. I've seen some done in a matte silver (aluminium) that looks pretty good too.
I'm just tired of seeing all the red calipers, so I'm off that kick.
Good Luck
Old Oct 25, 2006 | 08:28 PM
redrose's Avatar
redrose
wild ax guess = yes....if it falls off,redo with the hi-temp, not a big job even if the redo needs a wire brush in a drill motor to remove residual old paint.....standard auto enamel will turn black at abt 400*F, few will ever see a 800*(heavy usage) rotor long enough to absorb enough heat into the caliper to get to 400* skin temp
Old Oct 25, 2006 | 08:46 PM
VenkmanP's Avatar
VenkmanP
I used regular rustoleum and topcoated with clear engine enamel. About 15k fairly hard miles later I've had no problems.
Try the touch-up paint on one and topcoat it and try it for a few months.
Old Oct 25, 2006 | 08:58 PM
Carpenter's Avatar
Carpenter
I agree the all red caliper looks a little ....too....overdone. So I painted my calipers red and the caliper frames silver using high heat off the shelf colors. Then clearcoated them with high heat clear.
I also painted the rotors silver/clear at the same time. (Sadly, I learned how small a footprint the rear pads have on the rotors so had to re-do the back rotors again).
I did this during a brake job (all new parts, painted on the bench) two years ago and they're still looking great.
Old Oct 26, 2006 | 08:53 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
Silver would look hot on your aqua car
Old Oct 26, 2006 | 12:04 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Not sure what you mean by "car isn't driven as a DD"...is it just driven occaisonally or is it a track car??
As a sidebar, I painted the calipers on my DD Scirocco with ordinary spray paint about three years ago. They still look nearly as good today as they did 60,000 miles ago.....
I'd say you can use touch up paint for a normally-driven car.
Larry
code5coupe
Old Oct 26, 2006 | 12:22 PM
Muffin's Avatar
Muffin
I used engine paint. Works very well. Sorry but I painted mine red. Couldn't think of anything that would go with yellow.
Old Oct 26, 2006 | 03:06 PM
bluedevil99's Avatar
bluedevil99
Similar to the touchup idea, Im actually going to have a shop color match the paint to that of my car and paint the calipers, fuel rail covers, and a few assorted engine pieces. I have the aqua too. And Im doing black/aqua, so I dont wish to deviate a lot. If I had to pick something else, Id choose silver.
Old Oct 26, 2006 | 06:46 PM
phat87's Avatar
phat87
2021 C4 of the Year - Unmodified Finalist
Default yellow and red
Right on Muffin Man;
Lets see some pix of that vett of yours!!!
yellow phatty with red cals
Old Oct 26, 2006 | 06:58 PM
LS6 Motor's Avatar
LS6 Motor
You could powdercoat them, but unfortunately you would have to disassemble everything first. I was in the process of rebuilding all four of my calipers, so that is the route I took. I did the calipers in red, and the brackets in black.
Powdercoating is literally a world of colors, but they do bake them at 400 degrees, which is why everything needs to be removed.
Old Oct 26, 2006 | 07:42 PM
airblaine's Avatar
airblaine
i was wondering if anyone would mention powder coating. i powder coat all my small pieces myself and will do my calipers sometime this winter. these cars are old enough where they would benefit from a rebuild on the calipers. i beleive they are aluminum right? i also polish so i may try that as well.
To Painting Calipers
