91,Drain the fuel.
Old Oct 26, 2006 | 06:08 PM
Mikema's Avatar
Mikema
8th Gear
Default 91,Drain the fuel.
I would like to find out the best way to drain the fuel out of my gas tank. Can anyone help?
Old Oct 26, 2006 | 06:14 PM
cmontel727's Avatar
cmontel727
Remove fuel filler door, take out rubber splash guard off the neck. Loosen and label all the hoses on the fuel filler neck. Then take out the bolts holding the sending unit and the fuel pump. Finally siphon out old gas and reassemble in the reverse order.
Hope that helps
Old Oct 26, 2006 | 06:18 PM
Aardwolf's Avatar
Aardwolf
Disconnect the fuel filter under the passenger side and let it drain. Also if you need to you can run the pump but it can shoot fuel a long ways so becareful. Apply 12 volts to terminal "G" of your ALDL to do so.
To 91,Drain the fuel.
