C-4 Plenum Screw Removal?
Old Oct 27, 2006 | 10:07 AM
tls630's Avatar
tls630
Default C-4 Plenum Screw Removal?
What is the best way to get the 3 torx screw's out? I have one loose and the other 2 are frozen in there. I am soaking them in P.B.Blaster the best I can.I just put it on the top and hope it will work it's way down. Any idea's?I hear these screw's are a problem. My first C-4. Thank's in advance . Viet
Old Oct 27, 2006 | 10:17 AM
mseven's Avatar
mseven
what I did was to put the torq driver in the screw and then tap it with a small hammer from the top, and then try and loosen it.
Old Oct 27, 2006 | 10:26 AM
Bob CTS's Avatar
Bob CTS
If you are careful how about a little heat, when you get them out don't forget to coat the threads with a little anti-seeze to prevent this from happening in the future.
Old Oct 27, 2006 | 03:24 PM
tls630's Avatar
tls630
I have tried tapping on them, I do that when I have anything like that and it usually work's, but not this time. I don't know how you would get any heat to the screw.Possibly by putting a little heat on the plenum itself would help. Definately on the anti sieze.thank's guy's, any other idea's? Viet
Old Oct 27, 2006 | 03:40 PM
92Beast's Avatar
92Beast
Heat it up so it will melt candle wax and put a candle on it so the heated wax can flow down around the treads. I have had this work on tough bolts after other lubricants did not.
lallend's Avatar
lallend
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
Did you use a screw driver type handle w/torx bit? Turn and tap handle with hammer at the same time.
Old Oct 27, 2006 | 03:44 PM
mseven's Avatar
mseven
micro-torch might be the next step.....I still believe in tapping it, or maybe BFH
Old Oct 27, 2006 | 03:47 PM
tls630's Avatar
tls630
I tried the screw driver type as well as ratchet type. I did not try tapping while trying to turn it. I put a screw driver in it and tapped on that lightly.I am willing to try almost anything. I have alway's had very good luck with blaster, but I think it met it's match this time. Viet
Old Oct 27, 2006 | 06:27 PM
williammackean's Avatar
williammackean
St. Jude Donor '07
Get a drill with a nice clutch. Put the bit in it. The vibrating from the clutch engaging has a way of shaking things loose. This works for me one time in four. I call it the poor man's impact wrench. Unless you want to spend the $$ on an electric impact. Just set it LOW and but impact rated bits.
Old Oct 27, 2006 | 07:56 PM
tls630's Avatar
tls630
thank's guy's I am going to try the ratchiting drill, idea. If I were to say vibrating drill i'm afraid my wife would see this and then there would be all hell to pay. Any other suggestion's? Viet
tls630's Avatar
tls630
Old Oct 27, 2006 | 08:27 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
try this with a torx socket:
http://www.thetoolwarehouse.net/shop/LIS-29200.html
Old Oct 27, 2006 | 10:46 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I use an impact driver on stubborn fasteners. Here is a pic for reference.
Old Oct 27, 2006 | 11:51 PM
Sam Lam's Avatar
Sam Lam
as I have a similiar tool....and it works Remember to use the anti-seize when you install steel bolts into aluminum.
Old Oct 28, 2006 | 03:01 PM
tls630's Avatar
tls630
I have 2 out of 3 loose. The problem is I think that the head on #3 is about shot. I have to go get a 15 mm torx. I am going to try and find a hardened set. Maybe Sears? And they should have the impact driver.I got #2 by tapping on the handle of the screw driver handle while turning it .Like I said I think 3 is screwed up in the head. If so do I have to drillit out? Viet
Old Oct 29, 2006 | 02:58 PM
tls630's Avatar
tls630
I got #3 . I ran all over town looking for a hand impact and no one had one. So I came home and looked at a t-20 and tried it. It barely fit the walloed out T-15.So I tapped into the 15 and tried the screwdiver handle and a hammer and tapped as I turned and it came loose. I need all new torx screw anyway. But It is OUT !! Thank's for all the great help and advice.. Viet
Old Oct 29, 2006 | 09:56 PM
johnash's Avatar
johnash
Default Bolt out
I had one once that was completely stripped out. But, I could get to the outside of the head.
I got a set of Bolt-Outs from Sears, and put one on that just barely fit the outside of the head. As you turn the bolt-out it digs into the head, and spun it right out!
Old Oct 30, 2006 | 08:32 AM
tls630's Avatar
tls630
Over a 2-3 day period and lot's of excellant help from this board I got all 3. I slept better last night thank's again to all who helped!! Viet
Old Oct 30, 2006 | 08:36 AM
Bob CTS's Avatar
Bob CTS
Great feeling now that's accomplished right?
To C-4 Plenum Screw Removal?
