how do I find my broadcast code?
Old Oct 29, 2006 | 05:17 PM
jeff32463's Avatar
jeff32463
Default how do I find my broadcast code?
88 coupe.I have never had to know my broadcast code until now. I want Alvin to burn me a chip. He needs the broadcast code from my chip. Where is it and how do I get to it?
Old Oct 29, 2006 | 07:23 PM
scranage's Avatar
scranage
It sould be right on top of your ecm, at least it is on my 92.
Old Oct 29, 2006 | 08:02 PM
gtadudeoh's Avatar
gtadudeoh
There is one possible place on the outside of the ECM case that it can be found. There are also two places on the memcal module inside the ECM. On the case look for a white label with the ECM part number. If it is there, the broadcast code should be in the upper right hand corner and consists of four letters. As for the memcal, there should be a silver colored sticker. It will be either on the top of the blue cover or below the blue cover stuck on the eprom. You should be able to see it through the circular hole in the top of the blue cover. Again, it will be a series of four letters.
To how do I find my broadcast code?
