Setting L98 timing
Old Oct 29, 2006 | 06:22 PM
Sirwilliam1229's Avatar
Sirwilliam1229
Default Setting L98 timing
I just purchased a timing light, because I suspect that the timing is off. I pulled out the shop manual, and found out that the timing is to be set a 6 degrees. The problem is that the timing marks, do not look like the one in the service manual. There is a large cut out, which I assume is 0 degrees. There are two notches below that and three above. Does anyont have a picture of one, or can tell me what I am looking at?
Old Oct 29, 2006 | 08:27 PM
RRT vette's Avatar
RRT vette
You will have to disconnect the EST wire first before setting timing so the ECM can't retard the timing. The larger indention is 0*. Each notch over to the pass side is 2*. Loosen the distrubitor hold down bolt and move the distrubitor to set timing. Tighten the bolt and recheck. Here is a pic of the EST.
Old Oct 29, 2006 | 11:24 PM
gtadudeoh's Avatar
gtadudeoh
I have a photo that should explain it well. The base timing is usually 6 degrees before TDC. The first v-notch left of the large zero notch viewed from the front of the engine.
Old Oct 30, 2006 | 12:23 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
C:\Documents and Settings\Darrell Vincent\My Documents\My Pictures\engine rebuild\after\img_1237.jpg
But not much help unless we have access to your computer!
How 'bout this:
Old Oct 30, 2006 | 10:07 AM
RRT vette's Avatar
RRT vette
With these good pics you should have no problem.
Old Oct 31, 2006 | 08:09 PM
Sam Lam's Avatar
Sam Lam
Ray: good picture and I think I will save this for my use and others. Thanks for the photo
Old Nov 3, 2006 | 08:04 AM
Sirwilliam1229
Thank you very much for the pictures. Mine is covered in rusty brown, and I can't make anything of it. Thanks again!!!
Old Nov 3, 2006 | 01:13 PM
RRT vette's Avatar
RRT vette
Did you get the timing where you want it?
Old Nov 20, 2006 | 07:15 PM
Qiken's Avatar
Qiken
Old Nov 27, 2006 | 12:56 AM
serge's Avatar
serge
From: Olympia Washington 91 Z07 Coupe, 6spd, Borla Exhaust, Perf. Ignition, K&N Filter
thanks for that picture, that explains alot, i just looked in this thread just incase, and I ended up learning something, this is a great forum.
Old Dec 21, 2006 | 07:52 AM
Archaea's Avatar
Archaea
does that est unplug recommendation apply to all C4's?
Old Dec 21, 2006 | 09:39 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
All L98's, can't comment on the LTx's
To Setting L98 timing
