VSS confusion
Old Nov 1, 2006 | 05:51 PM
bcswebco's Avatar
bcswebco
5th Gear
Default VSS confusion
Hello all !
New here and have to say this place is loaded with a wealth of info!!
Have an '87 auto that I recently obtained. Trying to replace the VSS pickup on the transmission ... thought it was pretty straight-forward until I went to the parts store to order one. Counter guy asked me if it was for a D9A or D9B? Ran home and looked up the RPO - found out I have a D9B (http://www.corvetteactioncenter.com/...o/8496rpo.html)
Anywho, that apparenly is bad news since the parts store (Advanced Auto) computer says D9B sensors are no longer available.
Any suggestions for a source on these? New if possible. Thanks!
Old Nov 1, 2006 | 06:30 PM
toptechx6's Avatar
toptechx6
Try this link, hope it helps.
http://www.transmissioncenter.net/sp...0gear%20driven
Old Nov 1, 2006 | 07:55 PM
CFI-EFI's Avatar
CFI-EFI
I believe there are a couple of after market suppliers of that VSS. It definitely is no longer available from GM. The D9B indicates that it is GM# 25007308. That number is used with speedo driven gears with 40 to 45 teeth. You can use the D9A (GM part number 25007224) for 35 to 39 tooth driven gears, by rotating it 180° and installing it upside down. I'll bet your Advanced guy couldn't tell you that.
RACE ON!!!
Old Nov 3, 2006 | 11:12 AM
bcswebco's Avatar
bcswebco
5th Gear
Thanks for all the info! I did find a listed D9B replacement made by GP Sorensen at the Parts America site (Part Number: 7799506) ... if I find out not available at ordering time, will go with the "A" version and try the 180 twist.
Old Nov 14, 2006 | 08:06 AM
billyrn's Avatar
billyrn
1st Gear
Default vss d9a and d9b help
RACE ON!!!
can i really use the d9a model simply by turning it upside down?? also how do i know that it is turned correctly?? thank you very much for your help billy 1985 c-4
Old Nov 14, 2006 | 02:06 PM
CFI-EFI's Avatar
CFI-EFI
No. I posted that just to screw with you.
RACE ON!!!
To VSS confusion
