LT1 timing set.... advice needed
Old Nov 2, 2006 | 10:08 AM
ZBRA's Avatar
ZBRA
Default LT1 timing set.... advice needed
Need a timing set for the '94 Corvette. Looking for the best quality that is a direct bolt in and will work with the stock timing cover and '94 Opti. What should I buy?
Old Nov 2, 2006 | 10:54 AM
byedan's Avatar
byedan
o.e. replacement from gm
Old Nov 2, 2006 | 12:11 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Oh come on. What a great time to go to an electric water pump and later opti so you can use a true double roller! Probably the GM is your best bet. You could check with some of the aftermarket companies too to see is there's a direct replacement upgrade. I'm not positive but I don't think the GM Extreme Duty will work with the early opti drive.
Old Nov 2, 2006 | 12:22 PM
STL94LT1's Avatar
STL94LT1
Lunati makes a timing set that will work with the Gen I opti. But, I've yet to see anyone running one. Summit Racing sells this set for ~$175.
Old Nov 2, 2006 | 01:02 PM
rickneworleansla's Avatar
rickneworleansla
When I do mine Im going with the Meziere HD pump for $200 and the coyles billet true double roller timing chain from summit for $76. Together, cheaper than the GM timing chain I think. Unless you are trying to keep it stock.
Old Nov 2, 2006 | 01:26 PM
ZBRA's Avatar
ZBRA
I'm not trying to keep it stock, but I have absolutely no interest in an electic water pump. I will be using a stock '94 water pump.
Old Nov 2, 2006 | 01:31 PM
RacerX70CC's Avatar
RacerX70CC
Default My personal recommendation..
Cloyes True Roller replacement set.. no fitment issues, no electric water pump BS, a high-quality piece. It's a large single link true roller setup, as opposed to the original "silent link" design.
Old Nov 2, 2006 | 08:38 PM
ZBRA's Avatar
ZBRA
What year are you running this on?
Old Nov 2, 2006 | 10:07 PM
93-383's Avatar
93-383
i have one but its just a better quality version of the OE setup In hindsight I should have upgraded to latter equipment for the double roller but I didn't see the point since my HP goal was only about 450
Old Nov 3, 2006 | 03:24 PM
RacerX70CC's Avatar
RacerX70CC
They're available for both generations, and I've installed them on both with ZERO problems. Not cheap though (nothing quality is).
Old Nov 3, 2006 | 06:10 PM
TRACKMAN2's Avatar
TRACKMAN2
im looking for a good set up also ,mine is for my 92 now permanent race car you got a part number?? for the cloyes
To LT1 timing set.... advice needed
