Octane road test
Old Nov 6, 2006 | 11:15 PM
VenkmanP's Avatar
VenkmanP
Don't know about L98s, but when the LT1 stock program detects knock it goes into "low octane mode" where it pulls a significant amount of timing and the car runs like crap under WOT. Stays in that mode until you restart the car. I could definitely see someone saying that it feels like it is missing in that situation.
91 is considered optimal (although often hard to find) for a 10.25:1 car.
There is no such "optimal" octane for all 10.25 cars. You can make a 10.25 engine in so many ways that it could be optimized at 85 or 105. For starters, DCR is what matters, not SCR.
In most cases, what matters is not SCR or DCR, or any engine parameter, but rather what octane the _tune_ was optimized for.
Old Nov 6, 2006 | 11:17 PM
VenkmanP's Avatar
VenkmanP
Originally Posted by CFI-EFI
You guys didn't read the opening post very carefully.
His complaint wasn't of knocking or detonation, which can be caused by low octane, but one of missing, which has nothing to do with octane. It was an invalid test with a Bubba conclusion.
RACE ON!!!
You didn't read the OP very carefully.
He didn't say it was missing.
Old Nov 7, 2006 | 12:03 AM
Red Tornado's Avatar
Red Tornado
1. i didn't see anything in the OP or his profile that indicated anything other than a factory, stock setup. who was talking about "making an engine"?
2. its a no sh!tter that you can build an engine with a wide range of outcomes. this has nothing to do with the OP.
3. the owners's manual says premium, and when our cars were built, "standard" premium meant 91 octane. 93 is overkill for a 10.25:1 stock car which includes factory tolerance stack. 91 is conservative, takes that into account, as well as being in any altitude in the country with a road.
So apparently you didn't read the OP carefully.
He didn't say his engine was "built" with a set of parameters different than stock.
Old Nov 7, 2006 | 01:00 AM
VenkmanP's Avatar
VenkmanP
what you meant was
Assuming that the OPs car is stock then 91 is optimal for his car.
Which is arguable, but not as clearly wrong as what you actually wrote.
Guess you didn't read your own post carefully...
Old Nov 7, 2006 | 06:12 AM
Red Tornado
c'mon Vis, you're mincing words and blowing steam
i'm coming over for breakfast
Old Nov 7, 2006 | 01:58 PM
CFI-EFI's Avatar
CFI-EFI
Really? Do you want to read that again? Also, go back and read all the hoops he jumped through testing to cure the problem. None of them were aimed at checking for or curing detonation, which is the only thing octane can affect.
Originally Posted by Bubba91
So, a couple of weeks ago I got a full tank of 87octane gas(sunoco). The vette ran like crud(like it was missing a cylinder).
Several people have described their cars as "running like crap" (4REGT4, yourself, and others, probably) when the ECM pulls timing. There is no question that less timing reduces power, but "runs like crap" isn't very descriptive of specific symptoms, just poor performance.
RACE ON!!!
