Header Question
Old Nov 5, 2006 | 02:53 PM
c4cruiser's Avatar
c4cruiser
Default Header Question
The '87 is ready for a new exhaust system and I am thinking about adding a set of headers at the same time. I will be doing a true dual system with a single cat on each side. I will not have any provision for running open exhaust. Haven't made any muffler choices yet.
The car is a 4+3 primarily used for autocross, occasional track days and general street driving. I don't do any drag racing. Current mods are a ZZ3 cam (older GM cam), balanced, port-matched intake runners and a Hypertec chip. The mods were done by a reputable shop before I bought it and it runs fine. I estimate the HP at around 280.
Most of the short and tight autocross courses I see allow me to run in 1st gear at the upper limits of the L98's ability to breathe (4500-5000 RPM) or some longer courses where I can run in 2nd at 2500-4000 RPM.
Given this, is it worth it to install a set of headers? Would I see enough of an increase in HP/torque to make it worth the money compared to keeping the stock tubular exhaust manifolds??
I assume that headers will require using a heated O2 sensor??
Old Nov 5, 2006 | 03:49 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Most end up using a heated sensor but some have gotten by w/o it I believe. The long tubes and good exhaust tuning beyond are definitely worth the trouble but what class are you running? If you're not already in SM2, headers will put you there. Definitely incorporate an X-pipe into the system to reap the maximum benefit in response and torque.
Old Nov 5, 2006 | 05:23 PM
vader86's Avatar
vader86
Well in autox conditions where youre at WOT, it won't matter what sensor you have.
But in general you may or may not need one, I'm not using one and my mileage is still better than before. It does depend on the distance of the O2 bung from the head though. Hookers wont, some TPiS users may like it but mine didnt need it. The headers will let it rev a bit higher and so the upper end/midrange would increase in power, so I dont see a reason NOT to add the headers if you can stand the noise.
Old Nov 6, 2006 | 01:26 PM
wro87's Avatar
wro87
Used a set of MELROSE on our 87' Quality was great and have 3" to the mufflers, no cat, no air, no egr, and they will sell you wha tyou want and you can get just the parts you need. Talk to Chris at Melrose for what you are looking for. wro87
Old Nov 6, 2006 | 01:28 PM
Mojave's Avatar
Mojave
Headers are legal in BSP.
Old Nov 6, 2006 | 02:18 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
do you have the site:??
Old Nov 6, 2006 | 05:38 PM
c4cruiser's Avatar
c4cruiser
http://www.melroseheaders.com/ It looks like they also have a complete exhaust system for the 86-91. Headers, exhaust pipes and X-pipe. From the pic, you only need mufflers.
To Header Question
