C4 Rust? Common problem?
Old Nov 6, 2006 | 11:11 PM
Deja Vu's Avatar
Deja Vu
2nd Gear
Default C4 Rust? Common problem?
Do C4 Corvettes suffer from rust problems like the C2-C3? I have owned a C3 with bird cage issues and have seen a lot of bad frames. I am looking into buying a C4 and would like some tips as to the problem areas with these cars.
Old Nov 6, 2006 | 11:13 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Yeah they have rust problems,depends on where the car lived its life.
Fuel lines rusted in the rear,the gas tank,rear sway bars,and some other hardware in the rear where rust can form are the norm with earlier C4's in the rust belts.
Old Nov 6, 2006 | 11:18 PM
VtVette's Avatar
VtVette
as mentiond above they can have rust problems but I've yet to see one that is anywhere near as bad as some of the C3's I've seen. I've never seen a C4 with a rusty frame or a badly rusted windshield frame (like the problems that plague C3's).
I had a guy bring me his 1980 for a paint job a few years ago. Car looked to be in pretty good shape. He asked if I could take a look at his leaking T-tops. Turned out his entire windshield frame was rotted away that alone added $2500 to the cost of the paint job.
Old Nov 6, 2006 | 11:25 PM
VenkmanP's Avatar
VenkmanP
From what I've seen there aren't significant concerns with rust on cars that have been taken care of. If it's been driven in salt or spent it's life at the ocean, well that's another mess entirely as with any car.
There are a lot of minor components that are steel with no paint or other protection, but nothing too critical.
Old Nov 7, 2006 | 12:17 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
The only rust I have is on the exhaust manifolds(as all cars do), the cats and the bar that holds the center spoiler on.
My car is driven daily even in the winter with salt on the roads. No problems at all. The rust I do have is from where paint came off and left bare metal, and it was like that when I bought it and the car was originally sold in Texas.
Little bit of rust on the brake caliper brackets.
Old Nov 7, 2006 | 02:13 AM
Frizlefrak's Avatar
Frizlefrak
My car originally came from Cocoa Beach Florida, and had rust issues around the windshield frame. Had everything repaired when I had it painted, but I was actually quite surprised to find out it was there.
It concerned me enough that I went over the whole frame with the car on stands and looked for any other issues, but didn't find anything. There was some surface rust on fuel lines, etc, but nothing structural. And since it's very dry here, there shouldn't be any more that come up.
But to answer the question, yes....C4's DO rust.
Old Nov 7, 2006 | 08:18 AM
Tom Piper's Avatar
Tom Piper
I've seen some problems with corrosion from Delco battery leakage.
It drips on the frame.
Tom Piper
Old Nov 7, 2006 | 08:33 AM
KeyWestJack's Avatar
KeyWestJack
Is there any truth to the windshield frame being rust prone, perhaps around the bottom?
Old Nov 7, 2006 | 08:58 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
The hood holders tend to collect rain and car wash water, too, if the drain holes get clogged with debris.
You can take a leaf blower or air compressor hose and force the debris out or you can buy one of those hood drain kits from Eckler's or MAM (Mid-America Motorworks).
Old Nov 7, 2006 | 12:20 PM
Tom Piper's Avatar
Tom Piper
I think the C4 frame is actually galvanized before it was painted.
Tom Piper
Old Nov 7, 2006 | 12:30 PM
onedef92's Avatar
onedef92
Tom Piper
It got dipped in a zinc bath with electric current passed through it to enhance the process...
Old Nov 7, 2006 | 12:47 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Tom Piper
I had that took a brush to the rust and repainted the area.
Old Nov 7, 2006 | 12:52 PM
onedef92's Avatar
onedef92
That aluminized exhaust is stout, too. I'm still running the O.E.M. unit and there's not a lick of rust on my exhaust system.
Old Nov 7, 2006 | 03:18 PM
VenkmanP's Avatar
VenkmanP
Yeah that's pretty common.
Old Nov 7, 2006 | 08:19 PM
Deja Vu's Avatar
Deja Vu
2nd Gear
Default Thanks
Thanks for all your comments. It is great to get input from others who have been there so I know where to look.
Old Nov 7, 2006 | 10:58 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Before I bought the car I have now, I looked at a 85 w/56k on it. When you looked at the vin thur the windsheild, there was so much rust, you could not read it. I don't know what happen to that car, but it had a clean car fax.
BTW, the car ran great. I was going to buy it until I saw the rust.
Old Nov 7, 2006 | 11:56 PM
tonymax2's Avatar
tonymax2
I think an overlooked area of corrosion in the C4 will be the aluminum parts that are in contact with steel. The design team had to develop an epoxy coating for the steel to prevent galvanic corrosion of the alum. This coating won't last forever since it's basically like good, heavy paint and, especially if the car is driven "normally" on salted roads and in generally wet weather, will fail eventually. The aluminum corrosion will be much harder to fix, perhaps only by replacement with another alum part or an aftermarket steel part. Steel "rust" can be fixed by weld replacing the bad section but the forged and heat-treated alum parts are not good candidates for weld repair unless reheatreated. I'm not even sure that is at all advisable for critical, highly loaded members like struts, driveshafts, knuckles, etc. I suspect by the time C4s are as old and scarce as C2s are, most of them will have many steel replacement suspension parts.
To C4 Rust? Common problem?
Old Nov 8, 2006 | 12:07 AM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
take a good look at the rad. support
ninetyfivevette's Avatar
ninetyfivevette
You never should-- it's stainless steel. Many, if not most car manufacturers went to stainless to meet the longer emissions equipment warantee requirements that started somewhere in the early 90's.
Old Nov 8, 2006 | 08:41 AM
Tom Piper's Avatar
Tom Piper
OEM is Stainless.
Tom Piper
