Wide Band 02 Recommendations
TIA
TIA
The ideal setup would be to run dual WBO2's so you can adjust bank-to-bank mixures and identify any bank-specific problems.
Practically, as stated above, a single one is fine for us normal people. Even most professional dyno tuners rely on a single WBO2.
I have a Techedge unit (one of their older ones) installed in an extra bung immediately after the header collector on the driver's side. My unit doesn't do logging, which really stinks. I'd strongly recommend getting one with the ability to log data against at least RPM and ideally MAP. That will give you the ability to determine where your fuel map needs to be adjusted.
BTW, my dyno guy just sticks the sensor in the tailpipe and never asked whether I have cats or not. Do I need to find another dyno shop?
-Justin
(heated) O2 sensor behind the cat to free up the bung in front for the WBO2??
A typical equilibrium chart for combustion gas OUT of an Engine looks something like this:
http://www.megamanual.com/PWC/emissions.gif
Typical gas composition OUT of the Cat Converter is whatever you read off a smog test:
for example, < 50 ppm HC & < 0.25 % CO. The gas composition OUT of the cat is NOT
the same as the gas INTO the cat; a new equilibrium state is reached after the cat's
(oxidation) reactions.
Also, a typical cat has air pumped INTO it to promote HC/CO oxidation. Thus the O2
reading AFTER the cat has no relation at all to the equilibrium conditions after the
Engine's combustion chamber.
From those facts, it seems safe to conclude that placing an O2 sensor AFTER a functioning
cat converter makes no sense at all, in terms of ENGINE control.
For a detailed discussion of WB-02 sensors (Nernst Cells) you might try this site:
In terms of datalogging, I believe Dataq still sells their small A/D converter box for ~$30,
including software. Last I looked they had upgraded it to 10-bit resolution, and it still
had 4 inputs, with 240 sample/sec recording. That makes it a vastly superior tuning
recorder to anything I've seen on the comercial UEGO units. There's a pic of an old Dataq board
on my CF site. HTH
TIA
the tailpipe, I'm getting garbage AFR readings?
However if I were paying for testing services I'd expect the technician to be able to explain
how his testing equipment works; provide documentation on the manufacturer's calibration
methods for that equipment; and have written records of the calibration history of the gear.
Numbers produced from uncalibrated gear (or by an untrained operator) are only numbers.
tj makes a good point though - at WOT the cat won't reach equilibrium, so the measurement
error will be mitigated for that condition - assuming the meter is calibrated in the first place.
However I spend most of my tuning time looking at part-throttle and transient fueling. Those
are the conditions that govern 'drivability' - and for those, a sensor before the cat is necessary.
Sampling at the collector is where a WB and a fast recorder show up ignition and fuel problems.
Then again, my cars spend most of their lives at part-throttle on the street, and need to pass
smog. If I were building a car to run only at WOT the objectives might be different. JMHO
The two most common sensors are the Bosch and NTK.
If you are running C/L, the BLM is the indicator you want to use, not the WB.The reason a WB is used for WOT tuning is that 1) the NB works in a very narrow range for AFR, optimized for Stoich., 2) at WOT, the AFR required is outside the range of the NB accuracy parameters and so the ECM is interpolating the PW required for achieving the commanded PE AFR. How accurate that ECM is depends on how close the C/L is to the magic 128 BLM. The ECM uses the last BLM before entering PE in order to calc how much longer the PW should be for WOT.
So, if your BLM is higher than 128, the ECM will interpret that the motor is running leaner than it should and actually enrichen the WOT AFR by a corresponding amount. All you guys that get your cars dyno tuned need to make sure the BLMs are locked at 128 before modifying the WOT AFR. Or make certain the BLM is at 128 or below before entering PE. Otherwise, the AFR will vary depending on whether the last BLM was below or above 128. When I go to the track I load a bin with my BLMs "locked" at 128 so the ECM doesn't modify my WOT VE parameters.
So scranage, if you are going to use the WB to tune your PT, then you'll need to run O/L. The VE table will not necesarily look the same depending on if you have tuned to 14.7AFR or a use the BLMs. Its one or the other.
For a nube this is probably clear as mud, but you'll get it like the rest of us have.
