Tuff braking... Hard pedal ?
Old Nov 10, 2006 | 08:08 PM
corvettedan22's Avatar
corvettedan22
Default Tuff braking... Hard pedal ?
Well ive owened the vette for 3 weeks. 85 c4.
I feel like when im driving, if i had to slam on the breaks, it would not stop fast.
The pedal feels a little hard.
Im going to take the tires off and check the brakes. Also hope its not the brake booster ??
Is this a normal vette brake pedal?????
Old Nov 10, 2006 | 08:10 PM
Pete K's Avatar
Pete K
The plastic booster tends to crack from time to time. Especially in cars with long tube headers. I would look at the booster and vacuum line first.
Old Nov 10, 2006 | 09:00 PM
Bob CTS's Avatar
Bob CTS
The booster started giving out on my 86 with those symptons and gradually got worse until there was no power brakes left. Talk about fun.
Old Nov 10, 2006 | 11:21 PM
FF1wms's Avatar
FF1wms
St. Jude Donor '11-'12-'13
Sounds like your booster. mine was. Same conditions on mine. Pull your brake booster vac line off and plug it. Drive it and test the brakes . If it's the same.....booster. If it changes it's probably not the booster. You might want to change your brake fluid too, and check your calipers to make sure your brake pads aren't hanging up. If the calipers/pads are ok, THEN check the booster.
Good luck
Bryan
Old Nov 11, 2006 | 09:21 AM
corvettedan22
Whats a booster like 225 $$
ALSO HOW HARD IS IT TO CHANGE IT?
Dan
Old Nov 11, 2006 | 09:23 AM
Pete K's Avatar
Pete K
Yes. $225 bucks or so. Pita to change.Mine took about an hour to r&r.
Old Nov 11, 2006 | 09:30 AM
corvettedan22
r&r ??
Old Nov 11, 2006 | 03:05 PM
FF1wms's Avatar
FF1wms
I got 1 on ebay for $65. 2 bolts to remove the master, I took my seat out(4bolts) for more room, take panel off above drivers legs, use an extension with a swivel, 2 bolts, undo the rod and it's out. Going back in is a PITA to get the nuts back on, but if you've ever done a heater core, this will be a breeze.
There is a rebuild kit for it I'm going to get to rebuild mine....if I can remember where I seen it.
Old Nov 11, 2006 | 11:40 PM
pcolt94's Avatar
pcolt94
R&R - Remove and replace.
A good 1/4 inch rachet drive set will be a great help with the inside nuts.
Just on prinicipal, check the vacuum, hoses and check valve just to make sure. Is there an RPM increase when you step on brake and can you hear any vaccume leak.
As said, lots of places to buy a booster, look around.
To Tuff braking... Hard pedal ?
