Can LTPWS Light Bulb Be Removed?
Old Nov 10, 2006 | 08:10 PM
JAKE's Avatar
JAKE
Default Can LTPWS Light Bulb Be Removed?
Before I begin disassembling the dash on my 96 LT1 I'd like to know if the LTPWS dash light bulb can be individually removed.
The LTPWS light has been "on" since I bought the car and now that the seller is balking at the cost he'd have to pay to replace two wheel sensors, I'm looking to remove the bulb, if that's possible.
When I buy new wheels, I plan to remove the remaining two wheel sensors and pretend the car never even had that option.
Hope someone has done this before and can walk me through the procedure.
Thanks,
Jake
Old Nov 10, 2006 | 08:30 PM
TankerVette's Avatar
TankerVette
after:
-taking a paperclip
-unbending it
-heating it with a lighter
-poking it through the front of the info panel...
-RAMMING THE DAMNED LIGHTBULB WITH THE PAPERCLIP UNTIL THE STUPID BULB BROKE...
I later discovered that the lightbulb can in fact be removed...
you do have to take the info center off, though...
Old Nov 10, 2006 | 08:49 PM
JAKE's Avatar
JAKE
Originally Posted by TankerVette
after:
-taking a paperclip
-unbending it
ROFL!
I think I'll use plan "B" and pull the info center. Thanks for that tip.
Jake
Old Nov 12, 2006 | 10:00 AM
jasenr's Avatar
jasenr
after:
-taking a paperclip
-unbending it
Man are you going to feel bad WHEN someone sees that and does it!, That or laugh your butt off!
Old Nov 15, 2006 | 12:32 AM
JAKE's Avatar
JAKE
Well, I had it today and it only took about 30 minutes, start to finish.
Removed:
Four screws holding console lid
Shifter button and ****
Three screws holding shifter console
Three screws holding Information Center bezel
Two screws holding upper A/C Vent
Three screws holding Information Center to be able ti access the bulb.
Pulled the bulb, then screwed everthing back in reverse order.
All in all, very easy.
Jake
Old Nov 15, 2006 | 10:54 AM
TankerVette
30 minutes?
Grrrrr....
Suppose i need to learn to control my rage...
Old Nov 15, 2006 | 11:15 AM
Red Tornado's Avatar
Red Tornado
Jake, what I did was remove the DIC cover, and put a piece of electrical tape on the underside of it.
Old Nov 15, 2006 | 05:23 PM
JAKE's Avatar
JAKE
Yep, I guess either way'll work, but once I reached the point of being able to remove the DIC cover, there were only a few screws left to be able to access and remove the bulb itself.
In fact, when I got to that point, I first tried to pull the bulb with a pair of needle nose pliars, but couldn't get a grip on the slippery surface.
Then I thought of just breaking the bulb with a philips screwdriver, but when I looked closer and saw I was "right there", only a few screws away from accessing the bulb from the rear, I decided "Hey, why not!?"
Jake
To Can LTPWS Light Bulb Be Removed?
