Injector Prices
Old Nov 11, 2006 | 11:24 PM
Achille's Avatar
Achille
Default Injector Prices
How about some votes for the best injectors for the money. I'm running a stock 90 coupe.
Old Nov 11, 2006 | 11:26 PM
Pete K's Avatar
Pete K
Most buy the ford motorsports 24 lb injectors from Summit Racing for $220
Old Nov 11, 2006 | 11:54 PM
tm2k's Avatar
tm2k
What are stock injectors lbs rated at on a 95 lt1
Old Nov 11, 2006 | 11:57 PM
Pete K's Avatar
Pete K
I "think" 24 lbs. But not certain though.
Old Nov 12, 2006 | 12:12 AM
tm2k's Avatar
tm2k
If stock is 24 lbs and I need new injectors would it hurt/help if I went to 28 lb injectors on a stock motor?
Old Nov 12, 2006 | 12:25 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
It won't really help and you'll probably need an AFR to go with it.
Old Nov 12, 2006 | 07:15 AM
badbubba's Avatar
badbubba
7th Gear
I know they do not get good reviews, but I just replaced mine with Accels. It is there second design, not the yellow ones. I got them from Summit for around $250.00. I have only put about 200 miles on them put they work great so far.
Old Nov 12, 2006 | 08:23 AM
mseven's Avatar
mseven
FMS (bosch)22# is what I would do for a stock 90 MAP car.
Old Nov 12, 2006 | 10:55 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Yeah mate, 24.87 lbs/hr
It wont help unless you need more flow, that is true, but it certainly wont hurt anything and you wont need an AFPR either. What you will need to do is change the setting in the ECM constants table for the injector size so the ECM knows what size the injectors are. (for the bloke with the question about the 95)
To Injector Prices
