abs pump running ?
Old Nov 12, 2006 | 11:00 AM
hddrsr's Avatar
hddrsr
1st Gear
Default abs pump running ?
Turned off the ignition on my 88 vette the other night and heard what sounded like a motor still running. Noise was coming from back of vehicle which at first I thought was the power antenna, but opened the cargo door behind the drivers seat and the noise was louder. Disconnected battery and reconnected hoping this might reset an electrical glitch but no luck. motor runs as soon as battery power is restored. Has anyone run into this problem ? Is there a relay that could be stuck and need replacement ?
Old Nov 12, 2006 | 11:17 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
You may find help in these
http://members.shaw.ca/agent86/ABS%20Electrical.pdf
http://members.shaw.ca/agent86/ABS.pdf
