heater core
Old Nov 12, 2006 | 07:27 PM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default heater core
I just completely ripped my dash out to replace the heater core. I had some wiring that need repairing so im glad i did it. My question is...what is the relay thats behind the dash instrument panel? This the section above the radio and behind panel. i can see a fuse for the rear window also. Should I replace these before i go through the hassle of buttoning up the dash again. Also i want to test out the heater core and new radiator i put in for leaks so i was wondering i can start the car without any of the instrument cluster and various plugs i dissconnected on?
Old Nov 12, 2006 | 08:08 PM
CFI-EFI's Avatar
CFI-EFI
The relay question might be more easily answered if people knew what you are working on. The best I can come up with is the horn relay. It ought to be fairly easy to check out or test. *I* can't think of any reason not to start the engine... if it will.
RACE ON!!!
Old Nov 12, 2006 | 08:27 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Yep, if we knew what year you're working on it would be easier to give an answer. I can tell you this, the heater core SHOULD have been checked before you put it in. Now is not the time to wonder if it's okay.
Old Nov 13, 2006 | 01:18 AM
PMARTINEZ92126
sorry about that. Its an 86 automatic with Tune port.
Old Nov 13, 2006 | 05:59 AM
86PACER's Avatar
86PACER
Old Nov 13, 2006 | 06:02 AM
86PACER's Avatar
86PACER
No need to replace said fuse if it's not blown and is the correct rating.
No instrument cluster needed for the car to start up and run.
Old Nov 13, 2006 | 09:59 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Did you take any pics. I have decided to take the long way with the heater core so i can tighten every fastener inside the dash.
Old Nov 13, 2006 | 12:30 PM
PMARTINEZ92126
no, i didnt take any pictures but the car is still apart so i will before i put it back together.
To heater core
