O2 sensor question
Old Nov 13, 2006 | 04:00 PM
tm2k's Avatar
tm2k
Default O2 sensor question
Does anyone know what sensors are what. I hooked my car up to a tech2 and have an O2 sensor that is bad(voltage to high). On the tech2 it only shows 3 sensors. Is there only 1 on the drivers side and 2 on the passengers side?
There error is showing bank 2 but what are the sensors called pre and after cat? It sensor 1 pre cat?
Old Nov 13, 2006 | 04:36 PM
Cold_B's Avatar
Cold_B
The second one is just to check the cats, it has no effect on the tune. Bank 2 Sensor 1 should be passenger pre-cat 02.
Old Nov 13, 2006 | 06:55 PM
RRT vette's Avatar
RRT vette
Correct.
Check the wiring and connections before condeming the sensor. It is more than likely bad but cover the bases.
Old Nov 13, 2006 | 07:48 PM
stormin310's Avatar
stormin310
I pulled a 141 code a couple years ago bank 1 sensor 2. Divers side post-cat.....About $55 to buy and replace didn't even use the special tool with the split socket for the wires to go thru took it back and got my money back.....
To O2 sensor question
