What does this conenctor do on a 87´?
Old Nov 14, 2006 | 03:57 PM
Lars87's Avatar
Lars87
Default What does this conenctor do on a 87´?
Well in relation to my coolant overheat problem (se other thread), i have found the connector to be broken.
What function does this have on a 87?
i have been told it differs fronm 85 to 88?
Old Nov 14, 2006 | 04:05 PM
Pete K's Avatar
Pete K
It is a bell shaped connector that connects to the aux fan switch on an 87.
Old Nov 14, 2006 | 04:18 PM
Jaxian's Avatar
Jaxian
Default sensor
That is the coolant temp sensor for your extra boost fan in front of the radiator. There are three coolant temp sensors on the 87 L98. That one, then one at the front of the manifold that sends its readings right to the ECM and a third on the passenger side also. The one you are looking is the one commonly spliced into so that it turns on both the front and back fans so you can have them both come on at 200 and go off at 180. This is because the ECM will normally turn on the back fan at 230 degrees which is great for emissions but bad for performance. Mid America makes the kit to replace that sensor you have in the picture with the lower temp one and the wires to splice the the other wires so it controls both fans. Hope this helps. I don't recall if the kit comes with a new connector end though.
Old Nov 14, 2006 | 04:54 PM
Lars87's Avatar
Lars87
so this wouldet affect the main fan NOT comming on...
Trying to find the reason why my main fan wont come on...
Old Nov 14, 2006 | 05:05 PM
Pete K's Avatar
Pete K
This would not prevent the main fan from coming on. 87's are very tough to fill. Air always gets trapped in the motor, causing the problems you are having. You need to cool the car, elevate the front, run engine with cap off till it causes the thermostat to open, rev the motor to 2000 rpm's and have a helper fill the system, and pop the cap on while the revs are up. After the system is "packed" watch the guage and allow car to idle up to 225 degrees. Fan should come on. If not, let the car cool, and it will suck coolant in from the overflow tank. Start the car and repeat the warm up process. It is a pain in the nutz sometimes.
Old Nov 14, 2006 | 05:25 PM
Lars87's Avatar
Lars87
ok...I will try and pack the system, thanks
Old Nov 14, 2006 | 06:01 PM
lefoy84's Avatar
lefoy84
Have you tested the relay?
Old Nov 14, 2006 | 08:10 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The knock sensor connector is the same as the aux fan switch connector. Your odds of finding one in Denmark, just doubled
Here is some info on the main fan operation, if you don't have this already.
http://members.shaw.ca/corvette86/Co...%20Control.pdf
Old Nov 14, 2006 | 11:32 PM
ozvette87's Avatar
ozvette87
Old Nov 15, 2006 | 09:42 AM
Lars87's Avatar
Lars87
wow yes...
Well i got it all working now, it was a loose connector Thanks for all the info!
Old Nov 15, 2006 | 08:09 PM
87vette's Avatar
87vette
Thats odd.. I don't see that on my 87.
Old Nov 15, 2006 | 09:08 PM
Pete K's Avatar
Pete K
If you do not have the aux boost fan, you will not have that connector or sender. There will be a plug in the head instead.
Old Nov 15, 2006 | 09:16 PM
87vette's Avatar
87vette
Then thats what I have.
To What does this conenctor do on a 87´?
