86 Vette
Old Nov 15, 2006 | 10:44 PM
ebm257's Avatar
ebm257
Default 86 Vette
Hi, please help!!!
I have never had this car in the shop!!!
And I don’t know what is wrong!
It always starts when it is cold
After running for an hour it will not start until it has set for an hour or so
Please Please Please Help me
ebm257
Old Nov 15, 2006 | 10:53 PM
C4boy's Avatar
C4boy
Pull the ignition control module from your distributor and see if Autozone or a mechanic can test it for you. That's most likely your problem. If you replace it, don't forget to use dialectric silicone on the new module. It helps dissipate the heat which burns them out.
Old Nov 15, 2006 | 11:14 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
And test your fuel delivery.
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
http://members.shaw.ca/corvette86/Ig...System-EST.pdf
Old Nov 15, 2006 | 11:55 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by ebm257
Hi, please help!!!
How about helping us first by filling in your profile info?
Old Nov 16, 2006 | 12:04 AM
mash557's Avatar
mash557
Hi, please help!!!
ebm257
Do you mean it won't spin over or will spin over and not start? If it won't spin, then it could be a heat soaked starter solenoid.
Old Nov 16, 2006 | 07:45 AM
86PACER's Avatar
86PACER
Clarification is needed. You need to tell us what you mean exactly by "not start". When it does not start:
Does it crank fine and just not fire up?
Does the stater not even click or spin when you turn the key?
A more specific suggestion can be given once this is known.
Old Nov 16, 2006 | 11:34 AM
CFI-EFI's Avatar
CFI-EFI
It takes air/fuel, spark, and compression (cranking) in order for it to run. First you have to figure out what is missing.
RACE ON!!!
Old Nov 16, 2006 | 01:34 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I guess he wasn't all that interested in getting help....?
Larry
code5coupe
Old Nov 16, 2006 | 01:47 PM
Arlon's Avatar
Arlon
My 86 is similar. Starts instantly when it's cold but it's a lot harder to start warm but you can smell the fuel when you crank it a few times hot. Sometime cranks for 2-3 seconds before it starts when it's warm and just been shut off for a few minutes. I know I have a leaky injector and I'm assuming it's "flooding" the motor. I know it isn't an ignition issue because I replaced all the ignition components during they recent tune-up. There's that replacement theory again..
Fuel delivery system is next on my hit list. Accumulating the parts as I find them.
If it's still harder to start after that, then I'll start trouble shooting..
To 86 Vette
