Centerforce Clutch!
Old Nov 17, 2006 | 03:34 PM
Herb's Avatar
Herb
Default Centerforce Clutch!
I'm just curious if anyone has tried the dual friction clutch and what they think of it.
I'm talking about pedal presure, chatter, grip etc.
Old Nov 17, 2006 | 06:07 PM
Brand-X's Avatar
Brand-X
It was fine to about 500 rwhp....
Old Nov 17, 2006 | 06:57 PM
AKS Racing's Avatar
AKS Racing
Mine didn't even last to that level. Maybe they have improved them since the mid/late 90s.
Old Nov 18, 2006 | 04:17 PM
SupaVette's Avatar
SupaVette
Mine was also great till i started climbing past the 400's
Old Nov 22, 2006 | 11:06 AM
XTwinTurbo's Avatar
XTwinTurbo
Fried Centerforce clutch went to McCleod Twin disk, much happier. Keep in mind the McCleod is more expensive.
Old Nov 22, 2006 | 11:25 AM
Brand-X's Avatar
Brand-X
ditto for me...
Old Nov 23, 2006 | 12:31 PM
lcvette's Avatar
lcvette
actually... the price is 100% completely dependent on hether or not your stock flywheel is wiped out and you have melted the rubber dampening material between the two mass sections. if you need to replace your flywheel.. then the mcleod wins hands down as it comes with a new flywheel, two discs, pressureplate, master cylinder and all hardware inclusing new flywheel bolts. the GM dual mass flywheels are about 7-900 bucks depending on where ya get them and I think the price is still going up. that doesn't include the new clutch assembly either. do yourself a favor if your clutch is slipping and has some miles on it.. bite the bullet and grab the mcleod.. it will hold the power, lastlonger, can be rebuilt to new specs for about 300 bucks by the manufacturer.. too many pluses! bottom line.. don't waste money on a lesser clutch because eventually your going to NEED the mcleod to handle the torque of FI!
Chris
Old Nov 28, 2006 | 12:31 PM
HuggerVette's Avatar
HuggerVette
I had the centerforce this summer, with slicks and no nitroz after 3 turns on the strip the clutch starting to give up.
With 100hp nitroz from second gear it worked. From first gear no chans for the clutch.
With 175 hp nitroz... hmm. Low temp outside all gears slipping. So now I´m upgrading for the mcloyd.
As someone said, new flywhell 200-300$, cluch 400$, about 700$.. Mcloyd is 1100$ al included.
It depends on how u use the car.
In my case I payed almost 1400$ for my centerforce with flywheel, a guy trickt me. He said that it gonna hold for 800hp..
And I live in sweden, so it´s hard to just return and ****.
/Andreas
To Centerforce Clutch!
