Hard Cold Start C4
Old Nov 18, 2006 | 02:46 PM
jsmykl's Avatar
jsmykl
2nd Gear
Default Hard Cold Start C4
HELP. I have a 1990 vette that I am having trouble figuring out why it will not start after sitting over night. Had it to 2 different Cheverolet dealers and they have not been able to fix it. I personally have changed the plugs, distributer cap & rotor and engine coolant temperature switch. The first dealership stated I had low fuel pressure 42 lbs, but it dropped of quickly when the pump shut off. I changed the fuel pump, pulsater, sock and and fuel filter. Still no luck, same symptoms. The second dealership stated the pressure was still low, asked what kind of pump was installed. I had bought a pump from auto zone, Bosh. The said that was the problem. Took out the bosh and I installed an AC Delco, bought from the dealership and did away with the pulsator. Still same problem. The ejectors have been tested and they tested good. Car runs perfect after starting and starts great when warmed up. The car starts imediately when cold if I give it a squirt of starting fluid so I am assuming it is fuel related, maybe bad pressure regulator?? Has any one run into this problem and been able to solve it. Thanks for any input.
Old Nov 18, 2006 | 03:24 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Anyone test the fuel pump relay ??
Old Nov 18, 2006 | 03:52 PM
RRT vette's Avatar
RRT vette
Did you ohm test or leak test the injectors?
Does fuel pressure build after the key is turned "on" not cranked?
Have you looked into the FPR vacuum line for signs of fuel?
Have you looked at the spark plugs for gas fouling?
There are only so many causes for a drop in fuel pressure after the pump stops. Leak in the metal or rubber fuel lines or connections/fuel filter connection, check valve, pulsator, FPR, injectors. The 42 psi sould pretty normal to me. Hope you kept the Bosch fuel pump.
The fuel pump relay is activated by the ECM after the key is turned "on", but for only 2 seconds. The oil pressure switch is the back up for the fuel pump relay and closes the circuit after the oil pressure reaches ~4 psi.
Old Nov 18, 2006 | 05:11 PM
lefoy84's Avatar
lefoy84
You need a mechanic that knows what the hell he is doing. These people are throwing parts at it. The trouble shooting procedure in the FSM will tell you exactly what is causing the press drop. I had a similiar problem where the fuel press would not hold. The procedure led me to the pulsator. Yours does not have a cold start injector so it's not that. Does the pump run when you first turn the key to on? The system runs the fuel pump for about 2 secs when the ign sw is turned to on to prime the system. When the key is turned to start it looks for distributor reference pulses to turn the pump back on.
Put a fuel pressure guage on it and see what happens during this cycle.
Old Nov 18, 2006 | 07:46 PM
jsmykl's Avatar
jsmykl
2nd Gear
The fuel pump relay was replaced before posting this thread. The relay contacts were intermitten, so I replaced the relay. Fuel pump does run for the 2 seconds when turning the switch on. The injectors were ohmn tested, but not leak tested. The spark plugs are not wet after cranking, so I suspect the problem is not flooding due to injector leak. The fuel pressure imediately rises to 43-44 psi upon turning the key, but drops quickly after that. The pulsator was eliminated when the fuel pump was replaced, fuel hose and clamps used to replace. The hose was taken off the fuel pressure regulator, no gas detected. I have checked the supply lines\hoses, no leaks found.
Thanks for all your suggestions, any more places to look would be appreciated.
By the way, what is the troubleshooting guide in the FSM?
Old Nov 18, 2006 | 08:07 PM
RRT vette's Avatar
RRT vette
Take the gas lid and rubber boot off. You will see three lines coming from the fuel pump assembly. As soon as you turn the key "on" and get fuel pressure pinch off the top right rubber hose (fuel feed line) above the tank. If the pressure holds the problem is a leaky intank pump hose or pulsator or faulty fuel pump (check valve). If it doesn't hold, use the same procedure and pinch off the bottom right hose (fuel return line). If it holds you have a faulty FPR and if it doesn't hold locate the leaky injector.
Old Nov 18, 2006 | 08:12 PM
SunCr's Avatar
SunCr
If it eventually starts, it's more than likely the injectors. Do make sure the battery is fully charged and you might just try priming the rail a couple of times by turning the key on and then off and back on (leaving it on each time for a couple of seconds) and then trying to start it. If it fires, I'd replace them - a cheapo set of Accels did wonders for me (and it left the showroom floor with a hard cold start) so after living with it for 12 Years, it was a nice change. By the way, my stock tested fine.
Old Nov 18, 2006 | 08:13 PM
lefoy84's Avatar
lefoy84
I repeat. Follow the procedure in the FSM. It involves clamping supply and return lines among other things. A good mechanic would have already done this. This isn't rocket science. If the pressure is bleeding off it can be caused by:
1. Grossly leaking injector or injectors.
2. Faulty FPR
3. bad check valve in fuel pump.
4. bad pulsator.
5. ruptured or leaking line.
I may have forgotten one or two but I think you get my drift. I could find the cause in less than one hour.
Old Nov 18, 2006 | 08:29 PM
SunCr's Avatar
SunCr
Wow - took me 12 Years - and yes, I ran all the tests - even bought a tool to energize each one and record the pressure drop. After buying a new set, sent them to Rich at Cruizin' Performance and he told me they tested fine, but wasn't surprised to hear about the hard cold start.
Go figure. This guy has a new pump (his second). He's checked the regulator and clamping the return line and letting it rise above 60 psi can kill it. Nothing wrong with checking the plugs or pulling the rail and with a paper towel underneath, see if any drip - but if you've gone that far on a 17 year old car??? Seems you just fork over 250 Bucks and replace them.
Old Nov 18, 2006 | 09:04 PM
lefoy84's Avatar
lefoy84
Quote me where it say he clamped any lines. He says he checked for leaks. Not the same thing. If he didn't clamp lines, he has not run the procedure.
Old Nov 18, 2006 | 09:07 PM
RRT vette's Avatar
RRT vette
To clear my statment up...just let the fuel pump run for the 2 seconds after the key is turned on. Don't try and pinch off the lines with the pump running.
Old Nov 18, 2006 | 10:05 PM
lefoy84's Avatar
lefoy84
Now we are getting somewhere from one Louisiana boy to another!
Old Nov 18, 2006 | 11:00 PM
SunCr's Avatar
SunCr
Well duh - forgot to suggest the other thing - Check the Engine Coolant Temp Signal (since it replaces the choke) - should be ambient (along with the Air Temp Signal) on a cold engine. You'll need a scanner to see what the ECM is sensing, but if the fan happens to be running (make sure the a/c is off), that's a another clue. I know you replaced it, but that doesn't rule out the ECM or the wiring and though you could wring out the wiring with a DVM, that still won't tell you what the ECM is doing.
Old Nov 19, 2006 | 12:11 AM
jfb's Avatar
jfb
It won't start because there is no fuel pressure and the injectors are not spraying fuel. The proof is when you can get it to start with starting fluid, but not without it and you admit the fuel pressure drops rapidly. The fuel pressure has to stay up long enough to start the engine during cranking and yours isn't staying up long enough. You need to find out why the fuel pressure drops so rapidly. Check out each of the 5 reasons lefoy84 listed in his post as to why fuel pressure drops rapidly.
Old Nov 21, 2006 | 02:10 PM
RRT vette's Avatar
RRT vette
jsmykl, did you get this thing figured out?
Old Nov 23, 2006 | 07:44 AM
Da Mail Man's Avatar
Da Mail Man
..hey suncr, i know you have "participated" in a few threads of mine regarding my chronic hard start issues. that in mind, if the Engine Coolant Temp Signal is messed up from the sensor and that device acts as a "choke" (so-to-speak), do you think that could be the reason i have to hold my pedal to the floor to speed up the start time and lower the cranking time? i am aware of the "flood mode" with the pedal to the floor. i also have an auto x-ray scanner and such, what would i be looking for as i am a novice with that device and have seldom used it. thanks!
Old Nov 23, 2006 | 09:58 PM
VetBoy89II's Avatar
VetBoy89II
After the car has been sitting overnight, hook up your scanner. Read what the Engine Coolant Temperature is. It should be the same as the ambient air temperature; in other words your coolant should be the same temp as the air outside.
If it is a lot higher than the ambient air temp then you most likely have a bad Engine Coolant Temp Sensor or a bad ECM or a compound problem of both (rare though). Change the Temp Sensor first because it's only about $10 from the dealer. After you replace the ECT, scan it again (before you try to start it) and check the Engine Coolant Temp. If it didn't fix the problem, you'll probably need to go with the ECM.
What happens is that the ECT Sensor sends a signal to the ECM as to what the Coolant Temp is. Once the Coolant Temp sensor sends this signal (along with some other sensors sending their info too) the ECM decides how much fuel to deliver, if the ECM thinks the temp is too high, it won't send as much fuel as it would if it decided the temp was too low.
BTW, the ECT Sensor is relatively easy to fix for any DIY mechanic.
To Hard Cold Start C4
Old Nov 24, 2006 | 06:36 PM
Da Mail Man
...i have 2 ecm's and swapped them both out for each other which made no difference a long time ago so, that is not the underlying problem....i think i remember looking at the scanner and the dash reading on the scanner if i recall correctly, read the same or w/in 2* of each other...the temp sensor is at the front of the engine and a bit of a pain to get to. i think i may have to remove the tb to get to it....also, if the ecm things the temp is too high and cuts back the fuel as you have stated it, why then do i always have to hold the pedal to the floor to shorten the crank process so the car starts faster?....teh injectors have passed a not too recent leak-down test and most all the major components have been replaced for "routine maintenence".....
Old Nov 25, 2006 | 11:20 AM
89C4's Avatar
89C4
Had the same problems with my 89 about 2 years ago; went through the same things that your are doing now.
The problem turned out to be the ECM, it was converting the temp sensor signal higher that what it should have been thus disabling the "rich" injector pulse width needed to start a cold engine. The fact that you can get it started with a shot of starting fluid ( I did that too) makes it a reasonable conclusion.
Also, my idling was screwed up when I did get it started, and, my coolant fan would come on way too early, like 125 degrees.
After I replaced the ECM, all the hard start, idling, and fan come-on problems went away. The car ran like new.
I had the original 165 ECM and when I bought the new one it was already upgraded twice to part number 88999194. I paid $103 for the new one.
BTW, like SunCr said, you will need a scan tool of some sort to read the temp sensor output; I used WinALDL software with my laptop.
Hope this helps; I know what you are going thru: Been there, Done that.
Old Nov 25, 2006 | 01:08 PM
SunCr's Avatar
SunCr
What Year are we dealing with? If it has a Cold Start Injector, you'll need to make sure it's grounded and spraying on start up. Otherwise, checking the CTS with a scanner makes it a lot easier. I lost my ECM too and with the fan running and no fast idle, I knew where to look. You can also simply substitute another CTS (you don't need to install it) and see what happens - compare signals, etc. If you have the original MULTECS, I'd recommend something else, regardless of how they flow.
