Lower Driver Side Cover Removal - 1990 C4
OK ... I am trying to get the lower drivers side cover off to get to the CCM (code C41 - lost communication to ECM / also doesn't pull a C12 code) and I can't seem to get it out ... I have it to the point where it hangs down but still seems to be attached somewhere way in the back by the firewall ...
Has anyone done this before ... any ideas?
If code 12 doesn't display, the ECM is probably bad, the Eprom could be bad or there is no power to the ECM.
From your description it appears, you shorted pin G to A and turned the ignition on and saw Module 1 CCM code 41 displayed on the Dash Cluster. That indicates the CCM is probably good but can't communicate with the ECM.
[F|E|D|C|B|A]
[G|H|J|K|L|M]
) and was fixing all the little things that were wrong and this was the last thing that I needed to do (had the dash torn apart for the radio and radio receiver ... got that fixed) and then thought I would go a little further to make sure all the CCM cables were connected correctly.I think you are right though ... it is probably the ECM (looks like it was a rebuilt one). When I hook up my OBD-I code reader it can't communicate with the ECM (no serial data communications).
