Wheel leaking air
Old Nov 19, 2006 | 03:18 PM
RedHot94's Avatar
RedHot94
Default Wheel leaking air
I had posted this in Wheels & Tires, but thought I might get a response here...
I've purchased a set of ZR-1 aftermarkets from AFS about 4 years go. Two months ago, I had to replace one of my tires and now the new tire won't hold air for more than a week at most.
I finally took it in to have to tire reseated. When the shop was looking it over, they discovered the leak was was in the wheel, on the inside near one of the spokes.
I'm trying to figure out my options here...So far I have
1. Call AFS and replace the wheel.
2. Repair the wheel, if possible.
3. Squirt some Slime type patch in the tire and hope that will fix the problem.
Anyone have any other suggestions? I'm starting to have my doubts about AFS, they are still on ebay, but the AFS website isn't working right.
Old Nov 19, 2006 | 03:30 PM
cv67's Avatar
cv67
St. Jude Donor '05
Call them directly, 818-340-6181 Off, 818-340-0531 fax
Old Nov 19, 2006 | 03:55 PM
Tom Piper's Avatar
Tom Piper
Originally Posted by RedHot94
....Two months ago, I had to replace one of my tires and now the new tire won't hold air for more than a week at most.
It seems strange that replacing the tire would cause the rim to leak.
I had a problem where the tire would only lose air when the car was moving -- and then it would lose air fairly rapidly. The tire would go flat in about 30 miles.
You could submerge the tire and rim in water and see no bubbles at all.
The problem was the wheel weight -- but this could not happen with stick on weights.
Only when the tire was rotating with the weight of the vehicle on it did it lose air. Everytime the tire would rotate so the weight of the vehicle was on the spot where the wheel weight was would it leave out a puff of air. So, every revolution would emit a puff of air. The tire gets slightly distorted where the weight is on it and was causing the weight clamp to leave air out at the bead.
Replaced the weight, and the problem disappeared completely.
Tom Piper
Old Nov 19, 2006 | 06:27 PM
rickneworleansla's Avatar
rickneworleansla
Tom Piper
I had a slow leak that could not be found. I had two tire shops swear that one of my rims was bad after they installed new tires on them. After several trips to the shop and a lot complaining I finally convinced them to replace one of the brand new tires. New tire installed, problem solved.
Old Nov 20, 2006 | 12:04 AM
RedHot94's Avatar
RedHot94
I thought of that, but it won't work for me. The tire was from Tire Rack and I don't think they will send me another just to try out.
Old Nov 20, 2006 | 06:20 AM
toptechx6's Avatar
toptechx6
Get the tire installer to swap tires on the rims, then you will know.
Old Sep 26, 2021 | 02:51 PM
blackvette86's Avatar
blackvette86
Put an inner tube in it. Problem solved no more leaking air.
Old Sep 26, 2021 | 04:34 PM
RWDsmoke's Avatar
RWDsmoke
I had a tiny crack in a wheel on the SLK I had. After I finally found it I had it welded. No more problem. A repair on an aluminum wheel if done properly will be just as strong as before. But first you have to positively identify the leak.
Old Sep 26, 2021 | 06:05 PM
383vett's Avatar
383vett
In fifteen years, the op has gone through 3 sets of tires and two sets of wheels.
Old Sep 27, 2021 | 03:47 PM
Incorvettei's Avatar
Incorvettei
I just had a similar problem with my 86. Turned out to be the valve stem
Old Sep 27, 2021 | 08:33 PM
Duc96cr's Avatar
Duc96cr
Squirt some soapy water around the valve stems and anywhere else it might leak . Don’t take someone else’s word for it. Did they replace the valve stems ? Did you tighten the Schrader valves in the stems ? Some people use bead sealer, did your installer use bead sealer ?
Old Sep 28, 2021 | 11:51 AM
c.w.moss's Avatar
c.w.moss
Many years ago, I had a service station. A friend wanred some new wheels on his Duster. We ordered new wheels and new tires for it. They all came in, I got them mounted up and balanced, then put on the car. The next day he brought one of the wheels back by. It had gone flay overnight. It had less than 5 miles on it. I aired it back up and dunked it in a tub of water. Lots of bubbles. The tire didn't have any leaks, it was the rim leaking on the inside flat portion of the wheel. The cast aluminum wheel looked fine, but was porous and leaking air. The wheel had to be replaced.
To Wheel leaking air
