Engine cleaning Recommendation
Old Nov 24, 2006 | 06:31 PM
tims93's Avatar
tims93
St. Jude Donor '08-'09-'10-'11-'12
Default Engine cleaning Recommendation
Just installed a new intake gasket, and I need to clean excess oil from engine block. Any suggestions on how to keep the opti-spark dry? The car will be on a lift and will be pressure washing from below. Thanks-
Old Nov 24, 2006 | 07:16 PM
bogus's Avatar
bogus
be careful pressure washing from below. The K-frame won't protect it enough... if you do that, hit it from the front to the back, and be sure to stay about mid-oil pan. Don't go to far forward from there...
I use brake cleaner.
