Steering Wheel Play Question?
Old Nov 25, 2006 | 08:15 PM
CG77VETTE's Avatar
CG77VETTE
Default Play In Steering Question?
I recently noticed a slight amount of play in the steering wheel on my base '86. It's more noticeable at highway speeds and the best way I can describe it is if I'm cruising along at 65 mph, with my right hand on the wheel at 12 o'clock, I can rotate the wheel about an inch or more either right or left and there is no steering response. It does eventually catch and steer but not as quick as it used to. What can be causing this? I do have the steering rack morning sickness with hard steering on cold mornings, but once it warms up, no problems. Thanks for any help or suggestions.
Old Nov 25, 2006 | 10:12 PM
CG77VETTE's Avatar
CG77VETTE
ttt
Old Nov 25, 2006 | 10:16 PM
teufelhund's Avatar
teufelhund
How are your tie rod ends??
Old Nov 26, 2006 | 01:33 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default steering
check your rag joint
Old Nov 26, 2006 | 01:47 AM
CG77VETTE's Avatar
CG77VETTE
Tie rod ends are original with 107,000 miles. How do you go about checking them? I know north south movement in front wheel is bearing, is east west movement tie rods? Thanks for your reply and help.
Old Nov 26, 2006 | 01:52 AM
CG77VETTE's Avatar
CG77VETTE
Thanks for your reply. What and where is a rag joint and how do you check it.
Old Nov 26, 2006 | 05:40 PM
nonetooclose's Avatar
nonetooclose
To cure the morning sickness simply use some of that Lucas steering restorer. That stuff is incredible! Worked wonders on my rack, maybe it could help yours...
To Steering Wheel Play Question?
