Need opinion about this problem (urgent)!!
Old Nov 26, 2006 | 01:27 PM
Greenbeast's Avatar
Greenbeast
Default Need opinion about this problem (urgent)!!
Good afternoon all!!
Yesterday I did a couple of dyno runs on my C4 that has 383 stroker and supercharge engine.
Here is the problem:
When we dynoed the car in 4th for example, I accelerate the engine to 6k rpm and boost comes up to 12psi, then when I let off the throttle I notice good quantity of oil comes out from the oil check stick.
The mechanic here says that if that happen, is something bad internally in the engine. Like we need to change the rings on the piston of sometihing. (need open the engine?)
But then I think on something...
Oil pressure is perfect, like 40psi idle and 60psi when reving! And NO oil burned in the exhaust at all. (car feels good power) So I don't think that is the rings? Maybe is that issue normal and what I just need to tu put a security spring in the oil stick and solve the problem? The stick usually use the spring but yesterday we did not see the spring there.
So basically I want to know your real opinion about that.
Or tell me what test I need to do in the engine to be sure what's going on?
The engine has low miles.
Thanks for help!!
Old Nov 26, 2006 | 03:53 PM
Greenbeast's Avatar
Greenbeast
Originally Posted by bogus
What year is this C4? Is this engine L98 or LT1 based?
oil out the dipstick means too much crankcase pressure. That could be caused by blowby from the supercharger, and running a blower at 12psi is pretty sick.
Was the engine built with supercharging in mind? Or was the blower added later on? If the engine wasn't built for it, there is a strong chance that the rings have failed, or, a ring grove is giving up, allowing the rings to walk around too much. Also, if the gap is too wide on the ring, that would cause a problem.
Finally, it could be as simple as a bad PCV valve... I would check it. Do you still have the PCV hooked up? If not, then you have a problem...
Thanks for response.
Car is L98 engine. Engine is built for supercharger purpose. It has many custom things doned by Jim's performance shop.
Where is located the PCV valve?
BTW if something bad with the rings, should be smoking oil on the exhaust right? Mine is not doing that.
Let me know what to do, thanks again!!
Old Nov 26, 2006 | 04:13 PM
bogus's Avatar
bogus
Old Nov 26, 2006 | 04:16 PM
Sidney004's Avatar
Sidney004
It sounds like a compression test is in order to determine if there is a ring sealing issue. Even if it has low miles and was built with 12 psi in mind; a fractured ring or piston land can occur on a boosted engine pretty quickly. Do you use pump gas or racing fuel?
Old Nov 26, 2006 | 04:57 PM
Greenbeast's Avatar
Greenbeast
Old Nov 26, 2006 | 07:48 PM
bogus's Avatar
bogus
I have no clue what the compression should be... you really want to run a "leak down test." this tests the cylinders ability to maintain pressure over time.
I would hope that with such high boost, the compression ratio is rather low... like 8.5:1 or so. This is an issue with the build, it's not something you are going to measure now.
PS: I think the system clock freaked out earlier today.
BLWN BUX's Avatar
BLWN BUX
R . U Running a valve cover breather?
At 12 PSI you will have some blow by even if the rest of the engine is in order. The PCV valve will not do anything to relieve this presure!
Remember, the PCV valve is hooked to the intake. If the intake is under Boost, how could we expect it to suck out the blow by pressure?
It is better to run double check valves for PCV to insure that the boost pressure is not blowing back through the week little valve.
I Unhooked mine completly to eliminate the possibility.
You need a breather.
Old Nov 26, 2006 | 07:55 PM
BLWN BUX's Avatar
BLWN BUX
Compression PSI is variable depending on the combo. You could be between 150-250 . More importantly, they should be all within 10-15Lbs of each other.
Old Nov 26, 2006 | 08:42 PM
Greenbeast's Avatar
Greenbeast
I'm mixing race fuel with pump gas!!
What comprension numbers should be show in a good cylinder?
To Need opinion about this problem (urgent)!!
