Rear tire problem
Old Nov 26, 2006 | 09:13 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Rear tire problem
Both my rear tires are wearing bad on the inside, what would cause this to happen?
I replaced the shocks, before I got the tires and I replaced the right tierod about 8 months ago. The last set I had wore perfectly.
TIA
Old Nov 26, 2006 | 09:38 PM
JackDidley's Avatar
JackDidley
Camber needs to be aligned. Do it soon or tires will disappear fast.
Old Nov 26, 2006 | 09:59 PM
RRT vette's Avatar
RRT vette
get a 4 wheel alignment while your there.
Old Nov 26, 2006 | 10:02 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Or a least the rear.
Old Nov 26, 2006 | 10:50 PM
FF1wms's Avatar
FF1wms
St. Jude Donor '11-'12-'13
otherwise start looking for another set of tires.
Old Nov 26, 2006 | 11:41 PM
lefoy84's Avatar
lefoy84
TIA
If you changed a tie rod and didn't align it, the rear toe is out.
Old Nov 27, 2006 | 01:04 AM
DANSURE1's Avatar
DANSURE1
The man is right camber out.
Old Nov 27, 2006 | 02:54 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
I had the alignment done when I replaced the ujoints, come to think about it, that is when I started hearing the tire noise from the rear. I will have it rechecked, thanks everyone.
Old Nov 27, 2006 | 04:08 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Good point: too much toe-out can also wear the inside of the tires.
Larry
code5coupe
To Rear tire problem
