Coolant temp problem on 86 - help
Old Nov 28, 2006 | 09:05 PM
Mike263's Avatar
Mike263
Default Coolant temp problem on 86 - help
1986 coupe, aluminum heads. Stock.
Sitting still temp continues to go up, even after fan comes on. Drive and temp goes down to "normal" temp (195, in my case). It got up to 246 sitting still, and it was still rising. This is something new, I just started seeing.
Any ideas on what may be the problem?
Oh - I had a blown fuse two weeks ago for the fan. Replaced it and the fan comes on like it should.
Old Nov 28, 2006 | 09:33 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Are you sure the fan is turning fast enough and there is no debris between radiator and A/C condenser??
Is the coolant level ok?
Does coolant surge through the radiator when you reach over and crack the throttle?
Is the A/C on when you are checking coolant temp?
Turn on the heater full blast and see if coolant temps come down.
Old Nov 28, 2006 | 09:59 PM
C4boy's Avatar
C4boy
Have you replaced the thermostat?
Old Nov 28, 2006 | 10:05 PM
Mike263's Avatar
Mike263
Don't know about fan speed - looks and sounds normal.
Haven't cleaned out debris in about 3 years - I'll check it out.
Coolant level is OK.
AC currently not working - no refrigerant.
I'll check with the heater on.
Thermostat is 6 months old (180 deg).
Water pump is about a year old.
Old Nov 28, 2006 | 11:03 PM
RRT vette's Avatar
RRT vette
The thermostat is not the problem.
The main fan between the radiator and engine is controled by the memcal (chip) in the ECM. Stock temperature for the fan to come on is 227*. The fan will cut off at 217* stock. This is if you let it idle up to those temps. There is a fan relay on the driverside inner fender. The digital readout on the dash is controled by a coolant temp sender in the left head between #6 and #8 spark plugs.
You may have a secondary (aux) fan infront of the radiator that you can see if you look under the front bumper. Some C4's came with them and some not. That fan is controled by a sensor in the driverside head between #1 and #3 spark plugs. The on temperature for that fan is 235* stock. Note: (on 85 vettes the location of the coolant temp sender and aux fan sensor is just opposite from what I described).
That being said you, know what to look for with the fan situation. Make sure it comes on and goes off at those temps. This is if the chip is still stock.
The ONLY thing a thermostat does is control the warm up time and minimal operating temperatures. I bet it takes a little longer than it should to warm your engine up. On the highway your temperatures should be around 170* with that 160* t-stat. The stock degree t-stat for the L98 cars is 195* and for the LTx cars is 180* stock.
Take the radiator cap off when cool and start the engine and let it get to the same degree as the t-stat. The t-stat will open and let coolant circulate through the engine block. This is usually where the air is trapped. You will notice the coolant level in the radiator cap opening being to lower and may see bubbles. Fill the coolant as need. Let the engine get to where the main fan cuts on...watch for overheating. Now rev the engine to 2,000 rpm for a few minutes and check the coolant level again. After this the air should be out of the system. If you need to know more let me know.
Here is a test I did so you know what to look for:
I spent about 45 minutes observing the coolant temperature operation range on my stock (exhaust mods only) 86 L98 with 94,000 miles. Only modification to the coolant system is a 180* stat installed. I started the engine and let the temp rise. All the info is while at idle and the outside temp was 85*. Idle temp reached 227* before the fan came on and never saw the temp past 228* via only digital guage and verified by scan tool (TunerPro RT) to be correct. The temp dropped to 220* and the fan cut off. With the A/C on the temp sat around 205-210* at idle and stayed there. I consider this normal at idle and when driving at about 55 mph the digital guage/scanner stays around 180*-185* range.
For those that have questioned the operation of the coolant system on early and late model C4's, refer to this as it is normal temperature ranges in all coditions. Temps may rise faster and drop slower in hotter weather, but the operation of the fans are the same, controled by the ECM.
Check between the A/C condenser for trash (bird nests, leaves, plastic bags, anything that will block air flow to the fins). Make sure the air is out of the coolant system as temps will stay on the hot side do to air pockets. Make sure the coolant level is full and there are no leaks in the system. Make sure the fan(s) are operating as they should. Use only the coolant the manual says (green for my 86 and other years and Dexcool for the 95-96).
Old Nov 28, 2006 | 11:29 PM
96LT1's Avatar
96LT1
On the 86s the secondary fan (if there is one) is tied to the A/C and won't come on unless the A/C is on. You can jumper a couple of leads on the A/C circuit but that just turns the fan on permanently and there are more efficient methods.
1. Make sure that the system is topped off (and the overflow tank is full as indicated) and is free of air.
2. As mentioned check for debris between condenser and raditor and in front of condenser.
3. Have the radiator cap pressure checked.
4. If the cap is working properly be sure that the overflow system is working properly.
Old Nov 28, 2006 | 11:52 PM
C4boy's Avatar
C4boy
You're half right. If the thermostat doesn't fully open when it's supposed to, it restricts coolant flow to the radiator. Restricted water flow=less cooling. That would explain the higher engine temps at stand still.
Old Nov 29, 2006 | 07:33 AM
runner140*'s Avatar
runner140*
A place to start would be: pull the radiator and completely clean it and straighten out any and all cooling fins. Second would be to do a complete cooling system flush and replace with 50/50 distilled +coolant.
Check the two hoses and replace the radiator cap.
The above is for starters.
Old Nov 29, 2006 | 09:24 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Just so there is no confussion, the secondary fan on an 86 is controlled by a temp switch in the drivers side head.
Old Nov 29, 2006 | 05:53 PM
RRT vette's Avatar
RRT vette
Old Nov 29, 2006 | 07:06 PM
CFI-EFI's Avatar
CFI-EFI
The stat has nothing to do with it. Once it is open, it's done.
Take the radiator cap off when cool and start the engine... Let the engine get to where the main fan cuts on...watch for overheating.
Good luck with THAT test. With the cap off (cooling system not under pressure) the coolant will boil LOOONG before it reaches the fan on temp.
WRONG!
RACE ON!!!
Old Nov 29, 2006 | 07:33 PM
96LT1's Avatar
96LT1
Originally Posted by CFI-EFI
WRONG!
RACE ON!!!
Tell that to my '86. It will be glad to hear that.
Old Nov 29, 2006 | 08:32 PM
CFI-EFI's Avatar
CFI-EFI
You may have a defective fan switch or wire between it and the aux fan relay, but that wasn't the way it was built. Just check the wiring schematic in your FSM to confirm that.
RACE ON!!!
Old Nov 29, 2006 | 08:35 PM
RRT vette's Avatar
RRT vette
Is there a different way to get the air out of the system on 84-91 Corvettes? There are bleed valves on the LTx Corvettes. The radiator cap opening is the only way *I* see to get air out with out breaking a seal.
Old Nov 29, 2006 | 08:54 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The last car I checked with this problem had plastic bags blocking 75% of the radiator.
I've cleaned lots of leaves out of mine twice already. Last time I installed some adhesive weatherstrip under the condensor to keep it clean.
CFI-EFI's Avatar
CFI-EFI
Just do what you suggested. Run the engine with the cap off until the fan comes on. Let me know how that works out for you.
RACE ON!!!
Old Nov 29, 2006 | 08:57 PM
CentralCoaster
The fan will come on after all the water boils out. Once the oil cooks and the bearings start smoking, enough heat will get to the airbound fan switch to close it.
Old Nov 29, 2006 | 10:03 PM
Mike263's Avatar
Mike263
Default Upate on my problem
To answer some of the questions:
I don't have an auxilary fan.
My ECM chip turns the fan on at 195.
My thermostat opens at 180. I verified this.
Letting it idle in the driveway and checking things out:
I found that the fan doesn't always come on when it should. Sometimes it does and other times it doesn't
I found that if it should be on (based on coolant temp) and it isn't - tapping on the relay turns it on.
I may have just thought the fan was on when it wasn't. It's hard to hear in traffic with my exhaust.
I just replaced the relay.
I'm going to clean out between the radiator and condensor coil this weekend. The last time I did this was 3 years ago.
I'm optimistic this may get rid of my problem.
Thanks for the help, guys. Lots of useful info.
Old Nov 29, 2006 | 10:58 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default coolant
the only way I know of getting the most coolant in your car, is take off the radiator cap, start it up cold, open the throttle a little bit and run the engine to about 1300-1500 RPM, the water pump flows more coolant, compressing the air in the heads, etc.
add the coolant while the level is low with the engine revved up, and put the cap back on quick. Then let go of the throttle.
If the cap is any good, you will vent hot air with a little coolant into the overflow tank, and when it cools off, the recovery valve in the cap opens when the coolant in the engine cools off, drawing in the rest of the coolant it needs over several heating and cooling cycles.
In order for this to work, the overflow tank hose must be good, and the clamps tight.
watch your driver information panel, and make sure the low coolant sensor light doesn't come on, and you know it's full.
The information panel is coordinated with the radio, so that the radio squawks or chirps when a fault light comes on (factory Bose radio)
To Coolant temp problem on 86 - help
