Steering Rack size/width differences???
Old Nov 29, 2006 | 01:24 AM
BlackRocket's Avatar
BlackRocket
Default Steering Rack size/width differences???
Are there any width differences between the '84-87 steering racks as compared to the '89-96.
I was told that the earlier models are narrower???
Old Nov 29, 2006 | 09:08 AM
bully-85's Avatar
bully-85
yes there is a difference. Make sure they are exactly the same width before you give them your old rack. If you get the wrong one the toe-in
can not be adusted. I think the total differnce is something like 1".
Old Nov 29, 2006 | 09:46 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
What do you mean by narrower? Can't tell what you have. Please fill out your profile.
Old Nov 30, 2006 | 02:17 AM
BlackRocket
What I have is a custom one-off hot rod vette using a custom frame. The question to be more specific is that the '84-87 racks have shorter inner tie-rods than the '88-96. This is causing problems and I may just cut off the tie-rod ends off the rack and die some deeper threads onto the shaft.
I don't think this would throw off the steering geometry since I would be just shortening the outside dimension or overall width of the rack...
To Steering Rack size/width differences???
