Spot The Missing Part
Old Nov 29, 2006 | 04:58 PM
All2kool's Avatar
All2kool
Default Spot The Missing Part
This picture is from a '91. I notice it is missing something my '86 has - anyone?
Old Nov 29, 2006 | 05:19 PM
Chatman's Avatar
Chatman
Mass Air Flow Sensor
Old Nov 29, 2006 | 05:21 PM
lefoy84's Avatar
lefoy84
Is 91 a Speed Density motor?
Old Nov 29, 2006 | 05:35 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Yes, '90 & '91; that is the MAP sensor on the L rear of the Plenum.
Old Nov 29, 2006 | 08:44 PM
CFI-EFI's Avatar
CFI-EFI
Cold start injector? (Don't let kopbet see that.)
RACE ON!!!
Old Nov 29, 2006 | 08:49 PM
JackDidley's Avatar
JackDidley
Your car has a radiator cap. The 91 doesnt.
Old Nov 29, 2006 | 09:19 PM
All2kool's Avatar
All2kool
That is what I noticed. So, what is Spped Density, is it better, and can a MAF motor be converted?
Old Nov 29, 2006 | 09:58 PM
65Z01's Avatar
65Z01
I prefer the MAF reading air flow directly as opposed to the SD system where the ECM must read manifold pressure from the MAP and manifold temp from the MAT and then calculate air flow.
However, once a MAF engine is modified to where air flow is beyond the MAF's capacity, i.e. a count of 255, the MAF cannot accurately measure air flow.
You could "convert" from a MAF to a SD system; it would require yoiu to change the sensors, the ECM and the wiring.
Old Nov 29, 2006 | 10:02 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Speed Density was from 90-93.
Old Nov 29, 2006 | 10:09 PM
65Z01's Avatar
65Z01
Sorry Frank, I only deal with L98s...
Old Nov 29, 2006 | 10:41 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default maf/MAP
factory speed density is only good for stock motors.
any internal engine changes, and it throws a code.
your entire wiring harness has to switch from 2 connectors to 4 connectors and a new computer.
There's 2 computers, one for a generic like a camaro, or berlinetta or cavalier, and then one for corvettes that's sturdier. you install a custom chip after the install.
The advantage is the maf flows about 670 cfm, and the map system flows what ever the throttle body will flow.
disadvantages are custom chipsets every time you change heads, cam, headers, etc.
The computer has a look-up table that delivers the fuel based on all the sensors, knock, MAT, CTS, mat, MAP, vehicle speed sensor, tach signal,TPS.
The knock sensor is a different P/N also
Old Nov 30, 2006 | 12:16 AM
kopbet89c4's Avatar
kopbet89c4
Nice engine! SD setups are so much cleaner looking than an 80s MAF C4.
Old Nov 30, 2006 | 03:39 AM
Casethecorvetteman's Avatar
Casethecorvetteman
What a lot of garbage!!!
There is nothing wrong with this one... and it all works properly too....
Old Nov 30, 2006 | 04:08 AM
kopbet89c4's Avatar
kopbet89c4
Nice clean RHD engine Case! I like that mirror image look. At least its working alright for you. Although harder to tune and play with, I still think SD is still a lot neater though. Would you rather have to replace a $20 MAP sensor or a $500 Mass Air Flow sensor?????
Old Nov 30, 2006 | 05:20 AM
Casethecorvetteman
Tar mate. I kept it in top working order and reasonably tidy. Ive never had to replace either, and dont wish to replace any of them!!! If you like the right hand drive look, ship your car to me and ill convert it for ya!!! That will save you having to replace your tired old left hand drive steering rack
Old Nov 30, 2006 | 10:21 AM
CFI-EFI's Avatar
CFI-EFI
Is an SD engine with the MAP bypassed neater than a MAF car with the MAF bypassed? Since it will be bypassed and eliminated, what difference does it make if it is a $20.00 part or a $500.00 part? Either way, if one isn't smart enough to fix it, the hood should remain closed.
RACE ON!!!
Old Nov 30, 2006 | 11:09 AM
Casethecorvetteman
I think im going to be needing a bib if im going to drink at the computer while reading the CFI-EFI vs Kopbet89c4 threads
Got scotch running out my nose after that laugh
To Spot The Missing Part
Old Nov 30, 2006 | 11:15 AM
kopbet89c4's Avatar
kopbet89c4
Go get yourself a high quality one that won't soak through your shirt. Conformity vs. Innovation...
Old Nov 30, 2006 | 11:23 AM
Casethecorvetteman
And so it begins....
Common sense vs abomination!!!
Old Nov 30, 2006 | 02:57 PM
CFI-EFI's Avatar
CFI-EFI
Amen!
I'm gonna lay low here. Most can imagine what I'm thinking and have already beat me to it. I'm preaching to the choir, here.
I'm pleased if I was able to give you a chuckle, but don't waste that valuable stuff.
RACE ON!!!
