HELP CAR RUNNING HOT!!!!!!
Old Sep 25, 2001 | 12:26 AM
Izover4u's Avatar
Izover4u
Default HELP CAR RUNNING HOT!!!!!!
:mad hey guys my car is starting to run hot... it was like 60 degrees today cool and my car still hit 231..wtf?? i have a 160 thermo in it... before it never got past like 201-210 standing still then running in the highway it would be like at 178..Could the thermo go bad? It's the hypertehch one... So any info on this guys would help m out alot..thanks :cheers: :cheers:
Old Sep 25, 2001 | 12:33 AM
vader86's Avatar
vader86
Default Re: HELP CAR RUNNING HOT!!!!!! (Izover4u)
do you have your fans set to come on at 200 or earlier? have you cleaned your radiator lately?
Old Sep 25, 2001 | 12:39 AM
Izover4u's Avatar
Izover4u
Default Re: HELP CAR RUNNING HOT!!!!!! (vader86)
nope fans come on at factory settings i think 227 but even thou i didnt set my fans at 200 it never got higher than 220 standing still..running i was at 176 or soo..just now its getting hot....i did a coolant flush the other day but as far as taking the radiator out nope... have done that... but can the thermo just be bad...
Old Sep 25, 2001 | 03:11 AM
GlockLT4's Avatar
GlockLT4
It was in the 70's here today (maybe 80's) and i was around 190.. i thoght it would be a little cooler than that.. sitting it got up to 200. I hope it gets a little lower as the temps start cooling down some more.
Old Sep 25, 2001 | 11:46 AM
85 Dave's Avatar
85 Dave
If you haven't removed the radiator and cleaned it, you need to. I just removed mine because it was leaking, and I couldn't believe all the crap in there. Leaves, feathers, hair, cigarette butts, sand, rocks, dirt, pieces of rubber and scrap metal. About 1/3 of the radiator was completely blocked off with this stuff. I filled a grocery bag with all the stuff I took out. You can't see any of this unless you remove the upper radiator shroud.
Old Sep 25, 2001 | 02:14 PM
Rich_01659's Avatar
Rich_01659
Default Re: HELP CAR RUNNING HOT!!!!!! (85 Dave)
Izover4u, you did a coolant flush .......... there could be an air bubble in the block. there is a bleed port on the block some where. I've read about it but have not used it. seems that it was on the passenger side ...?? ask around or check a manual. good luck
Old Sep 25, 2001 | 02:30 PM
Camvette's Avatar
Camvette
Default Re: HELP CAR RUNNING HOT!!!!!! (Rich_01659)
Your 160 degree thermostat has nothing to do with how hot the engine gets. All the thermostat does is open when the car reaches 160 to circulate the radiator coolant. If the system is working correctly you can tell by your temp gauge when the thermostat opens because there will be a slite drop in temperature. This happens before the fans kick in.
If you did not burp the system after flushing, that's your problem. You have a air pocket. It's like being low on coolant.
Good Luck and AMERICA KICKS!!!! :D
Old Sep 25, 2001 | 04:20 PM
Izover4u's Avatar
Izover4u
Default Re: HELP CAR RUNNING HOT!!!!!! (Camvette)
well today guys i baught another 160 thermo.. and it lowered the temp...driving now im at 176 and at a stand still like 220...its like before thanks guys...
To HELP CAR RUNNING HOT!!!!!!
