Steering rack quick fix. Lucas?
Old Nov 30, 2006 | 10:19 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Steering rack quick fix. Lucas?
What kind of lucas oil do I need to shut up my steering racks' morning sickness?
Is there different kinds of lucas or will this quart I have that's thicker than midget snot do the trick?
Also do you think using Mobil1 synthetic ATF in the power steering could be partly to blame?
Old Nov 30, 2006 | 10:22 PM
B!@cK 86 V3tt3's Avatar
B!@cK 86 V3tt3
You put automatic Transmissiion Fluid in your powersteering pump? Lucas makes a soloution to help resolve powersteering problems? Thanks for the info.
Old Nov 30, 2006 | 10:25 PM
CentralCoaster
Well, I'm still getting groaning in the system when I drive it hard, even with the PS cooler. So I figured the magical M1 would have a higher boiling temp.
I'm starting to think though, that the fluid is just cavitating from a worn out PS pump. ATF and PS fluid aren't all that different, they're both hydraulic lubricants.
But that's a seperate issue from the cranky steering rack.
Old Dec 1, 2006 | 02:45 AM
86PACER's Avatar
86PACER
That's the one I used. I was about to replace the rack, but this worked and it saved me from having to. Not only did it clear the moaning and sticking upon a cold start up, but it also stopped a leak I had at the same time. I did nothing else. Have you bled the system?
Old Dec 1, 2006 | 10:48 AM
CrvtBB's Avatar
CrvtBB
Veteran: Coast Guard
I had the same problem. I drained my system, put in valvoline sythetic power steering fluid, and added a touch of the Lucas and haven't heard a peep out of my pump since even after pushing the car hard at Summit Point this summer.
Old Dec 1, 2006 | 03:25 PM
B!@cK 86 V3tt3
When I have my foot on the brakes say in the driveway and I turn the wheel, its like I have no powersteering. No squeaking. Just a real **tch to turn. I think its my powersteering pump. Is there a cheap "temporarily" soloution until I can get some spare $$ to fix it permanently. Is it even my power steering pump going wrong. Its not morning sickness. It's all the time. Does anyone know how much one would cost? Do they have rebuilt ones that are actually worth it. Sorry I am not trying to hijack the thread. Just asking since its kind of a topic here. Thanks.
Old Dec 1, 2006 | 03:36 PM
5pinball's Avatar
5pinball
hey cc for 6 or 7 bucks what have you got to lose ? use valvoline syn power st. fluid. lucas cured morning sickness 4 yrs ago. i put 2 bottles in summer and drain and put 1 bottle in winter. have had a new rack setting in garage for 4 yrs, when old rack goes, will put it in.
Old Dec 1, 2006 | 04:05 PM
Wheelman's Avatar
Wheelman
Just replace the rack. They are cheap.
Old Dec 1, 2006 | 05:12 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Kevin, I used Valvoline Syntech PS fluid. The stuff silenced the moaning immediately! Just siphoned the old fluid out and serviced. I repeated the procedure again about a week later.
After two years it looks (sounds) like I need to replace the fluid again.
Old Dec 1, 2006 | 07:18 PM
_twisted_'s Avatar
_twisted_
I used seafoams trans tune per the can, wrote a tech tip about it
PS Pump and rack/pinion maintenance
Old Dec 1, 2006 | 07:25 PM
aminnich's Avatar
aminnich
Lucas Power Steering Stop Leak is a synthetic and advertised to stop minor leaks (not your issue) and to improve rack performance. I do not know if it actually stops leaks, but I have had customer feedback that it seemed to make the steering 'easier'. Hope this helps.
ps-- I am NOT going to get into another debate over the benefits, or lack thereof, with Lucas products.
Old Dec 1, 2006 | 10:36 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I used the Lucas Power Steering fix it stuff.
Worked pretty good except for those cold mornings. The groaning went away unless it was below say 40 degrees.
Old Dec 2, 2006 | 12:43 AM
CentralCoaster
It will never get under 40 here, so it sounds like a great idea.
Also I should mention the Mobil1 ATF turns foamy after running it hard, what's up with that? I bled the system about 58 times.
I guess I'll just break down and put power steering fluid in my power steering system.
Old Dec 2, 2006 | 12:55 AM
pablocruise's Avatar
pablocruise
If he put trans fluid in the P/S <---- ()
shouldn't he put in lucas' trans fix fluid?
Hey Kev, how much P/S fluid did you put in the ZF6?
J/K
Old Dec 2, 2006 | 02:09 AM
CentralCoaster
J/K
No, I'm putting motor oil in there.
Old Dec 26, 2006 | 11:21 PM
CentralCoaster
Well, the Lucas concrete mix didn't perform too well, which doesn't surprise me. I added a whole bottle, like the bottle says too, and the pump is starving and groaning louder than ever. It's completely obscene for the first 5 minutes of driving.
It was loud as hell in 20 degree weather, and 60 degree weather.
I think my hose routing is causing air to get trapped in the cooler which is higher than the reservoir ports, but it's on the discharge side of the pump so it shouldn't matter. I sucked fluid out of the reservior with a turkey baster and refilled it, so there should be no need to bleed the system.
The system has always whined when hot, I suppose I should buy a new pump AND rack. Ho ho ho.
To Steering rack quick fix. Lucas?
