K&N Air Filter Question
Old Dec 1, 2006 | 10:36 AM
Biker's Avatar
Biker
Default K&N Air Filter Question
My '86 is bone stock. I'm thinking of adding a K&N air filter with a performance (open type) air filter lid. Can I expect any performance gains with this set up?
Old Dec 1, 2006 | 10:47 AM
86Pacecar's Avatar
86Pacecar
Not very much by itself but every mod helps when added up. Don't expect a noticeable difference.
Old Dec 1, 2006 | 11:24 AM
All2kool's Avatar
All2kool
You will gain 0.45 HP, none of which you will notice. A K&N does not filter as well as a good Fram, so expect a dirty intake. K&N is not what it is cracked up to be. Invest the money in Supreme gas instead.
Old Dec 1, 2006 | 11:36 AM
runner140*'s Avatar
runner140*
No.....save your money and buy gas.
Old Dec 1, 2006 | 11:49 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Typically the K&N + cut lid mod is worth 10chp or 1mph in the 1/4 mile; this is not enough to really feel on the street though.
Old Dec 1, 2006 | 12:07 PM
wolverine1967's Avatar
wolverine1967
i have just finished putting the K&N w/open lid in my 95.
i noticed better acceleration (punch)
and smoother shifting (used to hesitate a little)
for me it was worth the money in just the feel but i'm sure it doesn't add much HP if that's what you're looking for.
it just drives better than before.
Old Dec 1, 2006 | 12:12 PM
88BlackZ-51's Avatar
88BlackZ-51
i gained around 5chp.
Old Dec 1, 2006 | 12:16 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
No. Do not expect any gains on a stock motor.
Note: this is comparing a fresh paper filter to a fresh K&N. Many times someone will replace a used paper unit with a fresh K&N and feel like they are getting improved performance. They likely would have experienced the same improvement with a new paper unit...
Larry
code5coupe
Old Dec 1, 2006 | 12:45 PM
Biker's Avatar
Biker
Would a paper element allow more airflow if enclosed in an open type lid?
Old Dec 1, 2006 | 01:00 PM
rocco16's Avatar
rocco16
Yes, theoretically.
The question then becomes, does the stock engine NEED more airflow? I.e. is the stock lid not providing all the airflow a stock engine requires? I'm guessing the answer is that it is.
Larry
code5coupe
Old Dec 1, 2006 | 01:08 PM
wolverine1967
Larry
code5coupe
sorry, but i disagree.
i had a fresh paper filter in (wix) and replaced it when i got the K&N. it just runs better with the improved flow. and it's stock.
Old Dec 1, 2006 | 01:23 PM
rocco16's Avatar
rocco16
Originally Posted by wolverine1967
it just runs better with the (K&N)
"Runs better" is pretty vague.
Can you be more specific?
Larry
code5coupe
Old Dec 1, 2006 | 01:35 PM
65Z01's Avatar
65Z01
See Post #6.
Old Dec 1, 2006 | 01:43 PM
rocco16's Avatar
rocco16
i have just finished putting the K&N w/open lid in my 95.... i'm sure it doesn't add much HP if that's what you're looking for.
My cars always drive 'better' after I've washed them.
Seriously.
Larry
code5coupe
Old Dec 1, 2006 | 02:45 PM
rickneworleansla's Avatar
rickneworleansla
Seriously.
Larry
code5coupe
My favorite mod too.
Old Dec 1, 2006 | 03:00 PM
wolverine1967
Seriously.
Larry
code5coupe
Old Dec 1, 2006 | 03:14 PM
B!@cK 86 V3tt3's Avatar
B!@cK 86 V3tt3
Everyone here has there own opinion. I think most of these guys ignore the LONG TERM EFFECTS, of a K&N. Take a paper and a K&N new, they are the same. 10,000 miles down the road. OMG THE K&N IS FILTERING BETTER and still does not need to be cleaned for atleast another 6 months. That is worth it to me. K&N is reusable. Paper is not. Yes its more expensive now, but add up the paperfilters bought in the past. Gets pricey. Also open lid/K&N=10 chp. No you wont feel it but it does give a bit better acceleration and MPG.
To K&N Air Filter Question
Old Dec 1, 2006 | 03:20 PM
rickneworleansla
http://forums.corve tteforum.com/showthread.php?t=1563170&highlight=air+f ilter
http://forums.corve tteforum.com/showthread.php?t=1273178&highlight=air+f ilter
http://forums.corvet teforum.com/showthread.php?t=980513&highlight=air+fi lter
http://forums.corvet teforum.com/showthread.php?t=795272&highlight=air+fi lter
http://forums.corvet teforum.com/showthread.php?t=635168&highlight=air+fi lter
http://forums.corvet teforum.com/showthread.php?t=533212&highlight=air+fi lter
http://forums.corvet teforum.com/showthread.php?t=523676&highlight=air+fi lter
http://forums.corvet teforum.com/showthread.php?t=516763&highlight=air+fi lter
http://forums.corvet teforum.com/showthread.php?t=505812&highlight=air+fi lter
http://forums.corvet teforum.com/showthread.php?t=471119&highlight=air+fi lter
http://forums.corvet teforum.com/showthread.php?t=462012&highlight=air+fi lter
http://forums.corvet teforum.com/showthread.php?t=394279&highlight=air+fi lter
http://forums.corvet teforum.com/showthread.php?t=336751&highlight=air+fi lter
http://forums.corvet teforum.com/showthread.php?t=318836&highlight=air+fi lter
http://forums.corvet teforum.com/showthread.php?t=289389&highlight=air+fi lter
http://forums.corvet teforum.com/showthread.php?t=254070&highlight=air+fi lter
http://forums.corvet teforum.com/showthread.php?t=233147&highlight=air+fi lter
http://forums.corvet teforum.com/showthread.php?t=183314&highlight=air+fi lter
http://forums.corvet teforum.com/showthread.php?t=156669&highlight=air+fi lter
http://forums.corvet teforum.com/showthread.php?t=142407&highlight=air+fi lter
http://forums.corvet teforum.com/showthread.php?t=132912&highlight=air+fi lter
Old Dec 1, 2006 | 03:43 PM
Biker's Avatar
Biker
Seriously.
Larry
code5coupe
Less aerodynamic drag without the dirt, huh?
Old Dec 1, 2006 | 03:51 PM
Biker's Avatar
Biker
Back on topic... Someone on a different message board I visit said he used a K&N in 1994 Impala SS with the LT-1 mill. The airflow through the filter picked up a small amount of oil and coated the O2 sensor, giving the engine chip a corrupt reading. This was discovered when the car was being dyno tuned. Anyone ever hear of this problem?
