Sensor question
Old Dec 3, 2006 | 09:25 PM
JAKE's Avatar
JAKE
Originally Posted by CFI-EFI
That must be a carry over from earlier years, and a misprint for your 1987. With the ignition on, engine off, remove the connector from the switch and ground the wire in the connector. When the wire to the fan is grounded, the fan will come on. If it is the gauge sending unit, the gauge will max out.
RACE ON!!!
Years ago, I bought a Haynes book for my 86 and it had it wrong too. Only after a lot of aggravation did I find that out.
Jake
Old Dec 3, 2006 | 09:32 PM
JAKE's Avatar
JAKE
Originally Posted by Bob88Convertible
OK, now that we cleared that up, I think. I still have no place to put these sensors in the heads. What other options do I have to put these??? Thanks.
Bob
Well, I don't believe you have a lot of options.
I suspect the sensors/senders are tuned to the temps in the cylinder heads, so installing them in the intake would probably give you unreliable readings.
From what I recall, guys who have had the same "no holes in the heads" problem have had the heads drilled and tapped for the sensors/senders.
Any machine shop should be able to do it inexpensively.
I would first call Brodix just to make sure that the stock locations on THEIR heads can be used.
Jake
Old Dec 3, 2006 | 09:33 PM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by JAKE
Did you check to be sure there aren't holes with plugs screwed into threaded holes?
I recall AFR heads use to come without the necessary holes drilled and tapped for the sensors/senders. You may be walking the same road.
Jake
See post #2.
RACE ON!!!
Old Dec 3, 2006 | 09:42 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Is it the same on the 88?
Yes my aux fan switch is located on the LH side of the block below #1 & #3 spark plugs.
WRONG! The IP temperature gauge sending unit is in the right head, between the #6 and the #8 spark plugs.
Nope, not on an '88 L98. Mine is located just above the starter sol, in the block.
Old Dec 3, 2006 | 09:58 PM
JAKE's Avatar
JAKE
That's where my knock sensor is located - 86.
Jake
Old Dec 3, 2006 | 10:14 PM
CFI-EFI's Avatar
CFI-EFI
It is in the HEAD. There is no hole in the block, where you describe.
Yep! On an '88! I can't comment in what you, or someone before you has done to YOUR car, but your 1988 came from the factory with the gauge sensor in the right head. That drain plug hole is a poor spot for the gauge sensor being that low in the cooling system. Your gauge will read artificially low. Where the factory put the sensor, in the head, is a hotter location. So where is your knock sensor?
RACE ON!!!
Old Dec 3, 2006 | 10:32 PM
Raidmagic's Avatar
Raidmagic
RACE ON!!!
OK I did this. The drivers side made my aux. fan come on.(the one in front of the rad.) the Pass. side one did nothing. Which one runs the main fan?
Old Dec 3, 2006 | 11:35 PM
65Z01's Avatar
65Z01
...but your 1988 came from the factory with the gauge sensor in the right head.
Not true. Even my '88 GM Shop Manual shows the gauge sensor below #6 & #8 in the block and the aux fan sw in the block below #1 & #3, just where they are located on my '88.
The one on the RH side is for the gauges coolant temp.
The sensor for the ECM is in the front of the intake base to the right of the TB. The ECM and only the ECM controls the main fan.
If you want to test main fan control, open the small connector in the A/C pressure line and start the engine; the main fan should be running.
If that passes, jumper ALDL pins A&B and start the engine. The SES will flast at 2Hz for a while and then will slow to 1Hz when the ECM goes into closed loop mode. This requires a preset time delay, the O2 sensor in operation and coolant temp at a preset value. This will verfiy that the ECM's coolant temp sensor is working.
Old Dec 4, 2006 | 02:10 PM
CFI-EFI's Avatar
CFI-EFI
The fan in front of the radiator is the auxiliary fan. The switch in the drivers side head (1986 - 1989) is the axillary fan switch. When you grounded the wire in the right head, did you check the temp gauge (with the ignition on)? The right head (1986 - 1989) carries the gauge sending unit as I said in the passage you quoted. The main fan is controlled by the ECM which gets it's engine temp info from the ECT sensor in the front of the intake manifold.
RACE ON!!!
Old Dec 4, 2006 | 02:41 PM
CFI-EFI's Avatar
CFI-EFI
The illustration shows it in the head but the text does say otherwise. It was established in a thread on here a week or two ago, that the FSM does say block. It is a misprint. If you know the difference between a head and a block, go look at your car. The hole in the heads is actually on a plane higher than the spark plug holes, not "below #6 & #8" as stated. The spark plugs screw into the heads. There is no hole in either side of the block, the switch or sensor COULD be in.
As Jake informed you, that is where the knock sensor goes. You ignored answering, "I can't comment on what you, or someone before you has done to YOUR car, but your 1988 came from the factory with the gauge sensor in the right head. So where is your knock sensor?". Tell us.
RACE ON!!!
Old Dec 5, 2006 | 12:44 PM
JAKE's Avatar
JAKE
Originally Posted by lallend
Possible to see a pic of that Jake?
I just saw this post. I'll take some shots today and post them.
Jake
Old Dec 6, 2006 | 12:58 AM
lallend's Avatar
lallend
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
Jake
Old Dec 6, 2006 | 01:36 PM
  #33
CFI-EFI's Avatar
CFI-EFI
For those of you that say your temp gauge sensor and/or auxiliary fan switch are in the block, can you please point out where, on this block?
So all can see, here is where the sensor and switch REALLY mount.
RACE ON!!!
Old Dec 6, 2006 | 01:44 PM
  #34
JAKE's Avatar
JAKE
Jake
Sorry I couldn't get around to taking the shots. My new wheel hub/bearing assembly arrived and I spent my time installing it.
I haven't forgotten you though.
Jake
Old Dec 7, 2006 | 07:43 PM
  #35
cv67's Avatar
cv67
St. Jude Donor '05
If the holes are not just simply plugged, I would contact Brodix for advice as where, exactly, to drill and tap those holes. I'd bet where they are in the stock heads would be OK. I doubt you have two extra holes into water passages in your intake manifold.
RACE ON!!!
There should at least be some raised bosses where the holes ought to be drilled and tapped.
65Z01, where is your knock sensor installed right now?
Old Dec 8, 2006 | 07:51 PM
  #36
CFI-EFI's Avatar
CFI-EFI
How about it, 65Z01. Can you show is where your temp gauge sender and fan switch are mounted? How about the knock sensor?
RACE ON!!!
Old Dec 11, 2006 | 09:02 PM
  #37
JAKE's Avatar
JAKE
RACE ON!!!
I think he now realizes they are in the head and not the block. No need to rub it in.
Jake
Old Dec 11, 2006 | 09:52 PM
  #38
CFI-EFI's Avatar
CFI-EFI
I wasn't rubbing it in. I gave up asking days ago. I was letting the thread die, but I disagree. I don't think 65Z01 Has been convinced. He has posted numerous times, "not in and '88". You've said it, I've said it. Others have said it. Every time he came back with a refusal. I wasn't the first to post pictures. He has ignored repeated request for the location if his knock sensor. I don't believe he does know and it doesn't seem as though he is about to look at his own car to enlighten even himself. Him not knowing doesn't hurt you and me, but I hate to see the poison spread by someone who is that closed minded.
RACE ON!!!
PS. After all, look what got this thread started. It was a request for info on where to mount the sensor and switch in the new undrilled heads.
Old Dec 11, 2006 | 10:26 PM
  #39
JAKE's Avatar
JAKE
I recall what Chief Master Sergeant Scarborough told me more years ago than I care to admit. "When you admit to your mistakes, it builds character".
I guess I've got more character than most, having had to admit to so many. It comes harder to do for some than for others though. That may be the case now.
Sort of like drinking your booze straight, like the old time cowboys did when they bellied up to the bar; you've got to get use to it.
Jake
