Sensor question
Old Dec 3, 2006 | 05:13 PM
Bob88Convertible's Avatar
Bob88Convertible
Default Sensor question
I just realized the Brodix heads I just installed, do not have a place for the temperature sensor, or the fan switch. What other options do I have to install these. Thanks for any help.
Bob
Old Dec 3, 2006 | 05:19 PM
CFI-EFI's Avatar
CFI-EFI
If the holes are not just simply plugged, I would contact Brodix for advice as where, exactly, to drill and tap those holes. I'd bet where they are in the stock heads would be OK. I doubt you have two extra holes into water passages in your intake manifold.
RACE ON!!!
Old Dec 3, 2006 | 05:50 PM
JAKE's Avatar
JAKE
Bob
I know you're dealing with heads, but when I installed the MiniRam on my 86 there weren't enough drilled and tapped holes for all my coolant temp sensors either. I had three connections to be made but only two holes.
I ended up buying a short nipple and a 'T' in order to allow two sensors to use the same intake tapped hole.
Jake
Old Dec 3, 2006 | 05:55 PM
lallend's Avatar
lallend
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
Jake
Possible to see a pic of that Jake?
65Z01's Avatar
65Z01
Cruise-In II Veteran
On an '88 the ECM coolant temp sensor is located in the front of the intake base; the gauge coolant temp sensor is located in the RH side of the block.
There were no temp sensors in the heads.
Old Dec 3, 2006 | 06:08 PM
JAKE's Avatar
JAKE
What about the Aux fan switch? On the 86 it's in the driver's side head, right? Is it the same on the 88?
Jake
Old Dec 3, 2006 | 07:42 PM
Raidmagic's Avatar
Raidmagic
That's interesting, there are two sensors in the water jackets on the stock heads. One on the drivers side and one on the pass. side. What are these for?
BTW that's my dad the started this thread that's why I'm asking questions on his behalf.
Old Dec 3, 2006 | 07:45 PM
JAKE's Avatar
JAKE
On my 86, the one in the passenger side head is for the dash temp gauge and the one in the driver's side head is for the auxillary fan.
Jake
Old Dec 3, 2006 | 07:52 PM
65Z01's Avatar
65Z01
On my '88 (#113 Al heads) both the ECM temp sensor and the aux injector temp switch are located on the RH front of the intake base.
Old Dec 3, 2006 | 07:56 PM
CFI-EFI's Avatar
CFI-EFI
WRONG! The only thing "in the RH side of the block" is the knock sensor, just above the oil pan rail, in a block coolant drain hole. The only temp sensor in the block is just above the oil filter on the left side in the rear of the block, down fairly low. It is for the oil temperature. The ECT sensor IS in the front of the intake manifold. as stated. The IP temperature gauge sending unit is in the right head, between the #6 and the #8 spark plugs. The fan switch is in the same hole, in the other head, which puts it between the #1 and #3 spark plugs.
Maybe we can put a stop the THAT lore.
RACE ON!!!
Old Dec 3, 2006 | 08:04 PM
86PACER's Avatar
86PACER
Originally Posted by CFI-EFI
WRONG! The IP temperature gauge sending unit is in the right head, between the #6 and the #8 spark plugs.
RACE ON!!!
Old Dec 3, 2006 | 08:05 PM
CFI-EFI's Avatar
CFI-EFI
That is correct. That is also true of iron heads and the 128 aluminum heads, too. But last I looked, an intake manifold wasn't a block.
RACE ON!!!
Old Dec 3, 2006 | 08:09 PM
86PACER's Avatar
86PACER
Head, not block.
Old Dec 3, 2006 | 08:34 PM
JAKE's Avatar
JAKE
Originally Posted by 86PACER
Head, not block.
That's got to be the dash gauge sender if it's on the passenger side. If on the driver's side it's the aux fan temp switch.
Jake
Old Dec 3, 2006 | 08:44 PM
86PACER's Avatar
86PACER
Jake
It is. Note starter just below. I just did not specify what side, because both sensors swapped sides through out the years, and not cause confusion.
Old Dec 3, 2006 | 08:46 PM
CFI-EFI's Avatar
CFI-EFI
Jake
CORRECT! But only for 1986 - 1989. The 1984 and '85 cars had the IP gauge sender and the fan switch on the opposite sides as the 1986s and up. But ALL were in the HEADS!
RACE ON!!!
Old Dec 3, 2006 | 08:50 PM
Raidmagic's Avatar
Raidmagic
My 87 FSM says the fan sensor is in the pass. head. So which is right? How can you test this?
To Sensor question
Old Dec 3, 2006 | 09:09 PM
CFI-EFI's Avatar
CFI-EFI
That must be a carry over from earlier years, and a misprint for your 1987. With the ignition on, engine off, remove the connector from the switch and ground the wire in the connector. When the wire to the fan is grounded, the fan will come on. If it is the gauge sending unit, the gauge will max out.
RACE ON!!!
Old Dec 3, 2006 | 09:16 PM
Bob88Convertible
OK, now that we cleared that up, I think. I still have no place to put these sensors in the heads. What other options do I have to put these??? Thanks.
Bob
Old Dec 3, 2006 | 09:23 PM
JAKE's Avatar
JAKE
Bob
Did you check to be sure there aren't holes with plugs screwed into threaded holes?
I recall AFR heads use to come without the necessary holes drilled and tapped for the sensors/senders. You may be walking the same road.
Jake
