Hedman Headers what front Y pipe?
Old Dec 4, 2006 | 12:01 PM
corvette87's Avatar
corvette87
Default Hedman Headers what front Y pipe?
I am about to purchase a set of Hedman Elite's for my 87. What front Y pipe should I use?
Old Dec 4, 2006 | 02:21 PM
B!@cK 86 V3tt3's Avatar
B!@cK 86 V3tt3
Hooker 16720 Y-pipe. This pipe works with hooker headers. Maybe it will work on yours. Good luck.
Old Dec 4, 2006 | 05:01 PM
corvette87's Avatar
corvette87
thanks, I think it is my only choice unless I cut my stock one.
Old Dec 4, 2006 | 05:23 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Hedman uses Ball type flange and will not work w/hooker y-pipes. You will have to have one made, as I did.
Old Dec 4, 2006 | 06:47 PM
corvette87's Avatar
corvette87
thanks for the info.
Old Dec 5, 2006 | 09:15 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I used the stock Y with my Elites. It couldn't have been much easier.
Here is a pic before i mig welded the collector sockets on.
Old Dec 5, 2006 | 03:55 PM
rel3rd's Avatar
rel3rd
Straight shot???
It sure looks like it...or almost a straight shot.
What did you do, just cut it the length needed and weld the collectors on?
Old Dec 5, 2006 | 05:57 PM
AGENT 86's Avatar
AGENT 86
Originally Posted by rel3rd
Straight shot???
Yup
Old Dec 5, 2006 | 06:02 PM
rel3rd's Avatar
rel3rd
Originally Posted by AGENT 86
Yup
That's great. I was thinking that was possible with some of the longtubes.
fwiw, I made just over 500rwhp with 1-5/8" longtubes on another car. I can't see why I would/should need 1-3/4" longtubes (TPiS, Hooker) on something that makes 1/2 that, or less.
Besides, that'll open up the cylinder head budget some more...lol
How's spark plug access?
Old Dec 5, 2006 | 06:43 PM
AGENT 86's Avatar
AGENT 86
# 8 is the only tough one. Just like the stock exhaust
Old Dec 5, 2006 | 06:47 PM
corvette87's Avatar
corvette87
Just ordered the Elites. I will give your setup a shot.
Old Dec 5, 2006 | 06:52 PM
rel3rd's Avatar
rel3rd
Sorry to semi-hijack your post corvette87.
Please post back when you install yours.
Old Dec 5, 2006 | 07:13 PM
corvette87's Avatar
corvette87
No problem and I will.
Old Jul 9, 2010 | 01:44 AM
CDVBMX304's Avatar
CDVBMX304
Last Gear Tapped
I like your picture.
Did you delete the main center cat? I just purchased the elites, and I'm deleting all the cats on my 90'. I have a set of corsa mufflers. What do u do with the egr port(passenger side rear of intake) on the intake manifold? Plug it? I sure hope the ecm won't throw a code and make it run bad. Is there any 02 sensors in the exhaust on my car? As long as the sensor is in front of the cats, the ecm wont know if the cats are there or not, right?
Old Jul 9, 2010 | 08:00 AM
AGENT 86's Avatar
AGENT 86
Yes, I made a block off plate for the intake's EGR port and yes, I removed the main cat. I cut the the main cat's rear flange off and welded it to a piece of 3" pipe, so it was the same length as cat. That way my Magnaflow cat back is still a direct bolt on.
As for the O2 sensor, there is only one and it is before pre cat on drivers side. I bought an O2 bung and welded it into the ball socket flange that comes with the Elites. I didn't want to mess up the coating on any part of the header.
Old Jul 9, 2010 | 02:31 PM
CDVBMX304's Avatar
CDVBMX304
Last Gear Tapped
Thanks for the feedback AGENT 86,
What size bung for the 02 sensor (inside thread)? do you have any pics of the bung location?. Sounds like you lengthened your wires also. Soldered?
Old Jul 9, 2010 | 03:16 PM
AGENT 86's Avatar
AGENT 86
Go to your nearest parts supplier and ask for a weld on O2 bung. I'll look later for a pic.
I used a heated O2 sensor, so yes I had to lengthen and add a wire.
To Hedman Headers what front Y pipe?
Old Jul 9, 2010 | 07:05 PM
c4cruiser's Avatar
c4cruiser
Hedman makes a collector flange that already has an O2 bung welded in.
For the OP; you will have to remove the starter to get the passenger side header in place. Then re-install the starter before bolting the header in place. Once the header is installed the factory starter will not come out without pulling the header.
Also go really careful when removing the dipstick tube. That has to come out too.
Old Jul 9, 2010 | 07:12 PM
ch@0s's Avatar
ch@0s
Look at this:http://forums.corvetteforum.com/c4-t...te-videos.html
I followed Agent86's recomdation and it worked great.
Old Jul 9, 2010 | 07:48 PM
PBnf's Avatar
PBnf
I was just wondering, why wouldn't you go to a full dual exhaust system? Is it that much more complicated to build or is it a lot more expensive?
