Stall converter install?
Old Dec 4, 2006 | 02:56 PM
JJ 86's Avatar
JJ 86
Default Stall converter install?
How difficult is it to install a stall converter in a 95? Should I let a shop do the install? How much should i expect to pay for the labor? I'm wanting to do possibly a 2800 stall.
Old Dec 4, 2006 | 03:10 PM
Pete K's Avatar
Pete K
Typical shop rate in my area is $65 per hour. Typical time involved is 4-5 hours. This allows time for a filter change and to change all external seals in the trans while it is down. Add the cost of the seals, 12 qts of fluid and a filter and it should be less than $500. $400 if you are lucky.
Also, be sure to change the small o-ring on the end of the input shaft. This one never gets changed and is very important.
Old Dec 4, 2006 | 03:20 PM
STL94LT1's Avatar
STL94LT1
A friend just paid ~$300 to get a conveter installed in his truck.
Old Dec 4, 2006 | 03:51 PM
JJ 86's Avatar
JJ 86
Thanks guys.
To Stall converter install?
