mas to hi
Old Dec 4, 2006 | 06:49 PM
belzileb's Avatar
belzileb
8th Gear
Default mas to hi
Hi to all the good fellows out there.i have an 86 vert with a yellow light in the dash. it says 3 3 so i took my otc and scaned it and yes it is a 33 code mas to hi.is any body can help me.tks
Old Dec 4, 2006 | 07:17 PM
tequilaboy's Avatar
tequilaboy
Code 33 is basically a plausibility error for the MAF. Too much flow to be plausible based upon other conditions.
Flow > 45 gm/sec, with throttle < 14.8% and rpm under 3200 for 600 ms can set the fault.
You may want to clear the fault from memory by disconnecting the battery and see if it re-occurs.
Old Dec 4, 2006 | 08:52 PM
lefoy84's Avatar
lefoy84
You had a yellow light in the dash on an 86 that says 3 3?
Old Dec 5, 2006 | 07:14 AM
belzileb's Avatar
belzileb
8th Gear
done, and it still on.even trade the maf with my other vette.
Old Dec 5, 2006 | 08:29 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/Code%2033.pdf
Old Dec 5, 2006 | 08:32 AM
RRT vette's Avatar
RRT vette
Where are you from, belzileb? Can you fill out your profile for us?
Now, you say you had a code 33 and you disconnected the battery and the code reappeared? And you have swapped MAF and same problem? Did you disconnect the battery after the MAF swap?
Do you have a FSM (factory service manual)? You can follow the troubleshooting steps for Code 33.
Old Dec 5, 2006 | 09:54 AM
belzileb's Avatar
belzileb
8th Gear
tks agent 86 ill follow the steps.
Old Dec 5, 2006 | 12:31 PM
belzileb's Avatar
belzileb
8th Gear
ckt 993 unplug at maf power relay.tks to every one.made my day.
Old Dec 5, 2006 | 12:57 PM
RRT vette's Avatar
RRT vette
To mas to hi
