My '86 runs just fine. It has the very responsive Doug Nash 4+3, which I really like (hey, it's a 7-speed car). I've noticed that the car seems to shake on the freeway at 60+ mph when in OD 4th. If I 'downshift' into just 4th, shaking goes away. What would cause this shaking/vibration at 1500-1700 rpm?
So I replaced the Spark Plug Wires today with some Borg Warner 8mm's. The 'vibration' in 4th OD has disappeared and the car runs like new. As I was replacing the wires I did notice the Distributor was quite loose and could easily be moved turned in either direction. Amazing what new wires and a tight Distributor will do for a car. Car is much more responsive, idles great, sounds better, etc. BTW - the Borg Warner wires were on sale at Schuck's for $19.95.
