Sources for small plastic parts?
Old Sep 26, 2001 | 01:06 AM
Tom Mieczkowski's Avatar
Tom Mieczkowski
Default Sources for small plastic parts?
In changing out my fuel filter on my LT4 a few weeks ago, I loosened up several of the plastic retaining clips and pieces used to secure the fuel lines, both where they come off the fuel rail (on the engine side of the filter) and were they attach the fuel lines aling the rocker panel and aft. Many of these pieces look they are due for replacement. Is there any alternative to GM/dealer ordering these things? Is there anyone making specialty platic parts and clips for Corvettes. Has anyone ordred these from a dealer? Are the prices the usual outrageous overcharge or are they reasonable?
Any info is appreciated.
Old Sep 26, 2001 | 05:09 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: Sources for small plastic parts? (Tom Mieczkowski)
If youre talking abut the small black plastic pieces that the lines snap into there,and held onto the frame with a small bolt, you can get them from GM...dont know of any other supply store that carries them.
GM discontinued the clips on my 86 and I bought a few of the 96 style ones to work with my car, albeit I had some work to do to use them under the rocker panels etc.
The 86 used metal clips that rusted and were drilled in different places then where the 96 cars had them, but they were close enough to still use.
Theyre fairly cheap to buy and Id get them before GM discontinues them...that is unless someone here knows a better and cheaper source.
Some of the clips have 2 lines side byside and the bolt hole at the end, some clips have the lines on each end with the bolt going through the middle.Be sure to specify which ones you need.
Old Sep 26, 2001 | 05:26 AM
Shayne's Avatar
Shayne
I scored some from an electrical shop...they are a circle thats open with a hole for a screw to go through...its palstic and works perfect...kinda shaped like the letter P ........or b and the srew goes the the straight part...which is where the cable passes through to get inside the circle once you put the bolt in the holder is closed......dang I hope you got the visual on this one..becouse Im out of ideas.... :D
To Sources for small plastic parts?
