What is this please?
Old Dec 9, 2006 | 10:22 AM
todd_vette87
Guest
Posts: n/a
Hopefully I have sussed the way to put up an image. Can anyone identify the 3" square box please, and what it does?
On the earlier models that is the location for the knock sensor module... I thought that they kept it there through the 96s??? You had better dbl and trip. check on that before ordering. Normaly the knock-sens. mod. is thinner though???
I know this isn't a definate answer but i am trying to show another possability.
Old Dec 9, 2006 | 10:28 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Its not a knock sensor module. You must have missed posts #8 and #9.
His car is a 94, the knock sensor module is in the bottom of the ECM on 94-96 cars.
And it looks like this:
Old Dec 9, 2006 | 10:40 AM
lite blue's Avatar
lite blue
St. Jude Donor '12
Here's that area on my '91 Z. I got nuthin'!
Old Dec 9, 2006 | 12:01 PM
grahamecooper's Avatar
grahamecooper
Affirmative to Casethecorvetteman.
His picture is of the knock sensor module and it is located behind a gasketted cover on the underside of the ECU, with gauze ports to allow condensation to drain and on the underside to prevent the ingress of water. The module he illustrates is clipped in and after (literally) hanging from its clips for a few years, mine decided it was not going to make good contact with the ECU any more or the two knock sensors.
As a result, the Tech 1 said circuits were OK but no knock signal was getting through, nor (as a result) were any error codes being posted. This gives the impression that the circuits are fully functional when they are not.
Hope that helps others. Worth a check if you are getting pinging.
Graham
Old Dec 9, 2006 | 12:48 PM
grahamecooper
OK Mystery solved.
Section 5E2-10 ABS/ASR System, Helms says as follows:-
and we now know what its does.
I feel exhausted, and my XYF says she's had enough of this also.
Old Dec 18, 2006 | 03:05 AM
Sirwilliam1229's Avatar
Sirwilliam1229
I have a 1989 Vette, and it is called an Electronic Spark Control Module. I don't know what it is for! I posted a thread trying to find out what it is for. The shop manuel does not shed much light on it.
Old Dec 18, 2006 | 10:23 AM
Casethecorvetteman
Wrong model and wrong part SirWilliam
Old Dec 18, 2006 | 03:49 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
It is the interface between the knock sensor and the ECM; used on '85-'89 TPI.
