Which Opti to go with?
Old Dec 8, 2006 | 09:06 PM
Gixster's Avatar
Gixster
Default Which Opti to go with?
Again, I've been away for far too long.
Dealing with a '94 LT1. My water pump has started leaving it's mark on the ground under the car. Some days, it's a trail all the way out the back of the car. Others, not so much as a drop. It's driving me crazy to say the least.
I tore my '86 apart to replace the water pump, so I'm somewhat familiar with the procedure.
I have the factory manual for the '94, and I'll be tearing it apart soon to begin R&R of the pieces.
Any suggestions on who to go with for a water pump replacement? Also, who do you guys like for the Opti? I'm assuming that since I've got the car tore down to the water pump, I should probably go ahead and replace it, considering the car has 107k on it now. I've read the FAQ and seen DelTeq, LTCC, and Dynatech mentioned. Any preferences on who's better or worse? Where can I purchase them?
Thanks guys and gals!
Old Dec 8, 2006 | 10:55 PM
Lone Ranger's Avatar
Lone Ranger
DelTeq and LTCC both still utilize the signal from the opti, so you would need a new opti PLUS the Delteq or LTCC kit IF your current opti is indeed dying from the bath. So given that situation, if it were me I'd just go with a new Dynaspark opti unless you need the ultra high rpm capability of the Delteq or LTCC. If you even need a new opti. But I see your logic since you're going to have it apart for the water pump change-out anyhow.
Old Dec 9, 2006 | 02:13 AM
fuzzydawg's Avatar
fuzzydawg
You might check out MSD. They have an Opti replacement unit for around $550 that sounds - from the descriptioin - much better engineered than the original Opti.
Old Dec 9, 2006 | 12:08 PM
ROB502's Avatar
ROB502
Default Opti
The MSD is on Ebay for $422 plus @ $10 shipping. For the 92-94 and even cheaper for the 95-96 LT1.
Old Dec 9, 2006 | 12:23 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I'm still using the OEM OPTI, with the coil the car came with new. I don't see a need to go spend all that money if the car doesn't need it.
Old Dec 9, 2006 | 01:15 PM
franks96ce's Avatar
franks96ce
the msd opti is only $200 in the jegs magazine.
Old Dec 9, 2006 | 01:22 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
The OEM is just fine. It seems once higher RPMs and modified cars come into play that OEM gets to be a weak link. But, if I were to go back to a Opti I would go MSD, then Dynaspark then GM.
Not enough data on Accels replacement.
I use DELTEQ right now. I bought a 20-30 dollar broke Opti, cut the rotor down so there is just a cap to hold the round thing in there that has 360 holes in it that lets the Opti signal sensor send data to the Delteq for timing. I sealed the crap out of the cap with right stuff.
When putting an aftermarket Opti in a modified engine, fitment is of upmost importance, from the camshaft dowel pin etc on down.
Heres what they look like when improperly installed and too many rpms come into play
Old Dec 9, 2006 | 02:29 PM
STL94LT1's Avatar
STL94LT1
That's not the complete opti, just the cap and rotor.
Old Dec 9, 2006 | 02:40 PM
honda hunter's Avatar
honda hunter
Any reason you have the MSD over the Dynaspark? MSD had some issues in the begining but I think that was like a first batch thing. Ive also heard that the MSD is rated at a higher rpm than the MSD. What are your thoughts?
Old Dec 9, 2006 | 02:56 PM
steve40th's Avatar
steve40th
I think the MSD will/is better due to the fact it is all new parts. The Dynaspark is rebuilt with a few extra nice things, but it uses a modified rotor, for example. Its just my opinion, not to say any is better than the other.
Old Dec 9, 2006 | 05:15 PM
ericcer's Avatar
ericcer
I bought the MSD because it was rated at a higher RPM than the Dynaspark. The Dynaspark max RPM was not much better than a stock LT4 redline. Plus MSD makes great products.
Old Dec 9, 2006 | 05:58 PM
STEVEN13's Avatar
STEVEN13
Hi,
You may not remember me-you tried to help me with a Delteq problem I was having 2 years ago. Anyway-are you still using the Delteq? The Delteq never worked right on my 1992. Both JC and Pete came to my house to try to fix and even considered buying my car. Those guys are great I would never say anything bad-just curious if you still ran the Delteq.
Thanks,
Steven
Old Dec 9, 2006 | 06:17 PM
Gixster's Avatar
Gixster
Well let me ask this then.
The *only* reason I've been considering the Opti replacement is because I've got to strip the motor down almost that far anyway to do the water pump.
The Opti isn't giving me any problems yet, but from what I've read, when you're there, you should do it, especially on an 80k plus motor.
What's the concensus? Should I go ahead and replace it, or is it not worth the trouble if mine's still working at 107k?
Old Dec 9, 2006 | 06:24 PM
Ttime's Avatar
Ttime
I would replace it. I would be pissed if that opti failed a week later . Just my opinion
Old Dec 9, 2006 | 06:27 PM
ericcer's Avatar
ericcer
Originally Posted by STEVEN13
Hi,
Thanks,
Steven
I will be using the MSD opti and the Delteq with my new motor. I can't get any better than that.
Old Dec 9, 2006 | 08:49 PM
STEVEN13's Avatar
STEVEN13
Old Dec 27, 2006 | 03:03 PM
Gixster's Avatar
Gixster
Well guys the water pump is still leaking sporadically. I've driven the car for 2 weeks now, and it hasn't hiccupped or quit on me yet, but I am going to start tearing it down this weekend I hope.
From what I'm reading, it seems the concensus is to go ahead and replace the Opti? Mine's working, and I'll pop the cap off to check it when I'm in there, but if everything looks fine, should I really bother?
If I do anything distributor related, I'll replace it. I thought about just replacing the cap/rotor assembly, but GM wants $442 for that. Little on the ridiculous side when an MSD Opti isn't much more.
This should be a fun project, along with my steering rack that started getting a little stiff every day or so. Guess I'll get some Valvoline Syntech ps fluid for it and see if that will fix that problem for a while.
To Which Opti to go with?
Old Dec 27, 2006 | 03:45 PM
93cruiser's Avatar
93cruiser
Check to see if your waterpump drive shaft seal is leaking oil. If it is, I suggest swapping to an electric water pump. If you stay with the conventional water pump, go ahead and buy a new shaft coupler. The reason you need one is the bad bearing in the water pump can ruin the splines in the coupler. If you do not notice the oil leak then your lucky. This leak if very hard to stop. I have been into my 93 twice trying to correct the leak.
Just a little bit of advice.
93cruiser
Old Dec 27, 2006 | 11:45 PM
resipsa's Avatar
resipsa
If your waterpump has been leaking and your engine has 107,000 miles on it, odds are that your Opti will need replacing soon. I cant imagine how the rotor and cap are not worn with that kind of mileage. However, I wouldn't spend any more money than I have to (e.g., for multicoil units) unless you are seriously building the motor.
If it was my car, I'd buy a new GM Opti. I've purchased two "high performance" aftermarket distributors in the past (looong time ago). The first one was made by Accel, and it was total junk (my experience with their spark plug wires and coils has not been much better). It lasted less than one year. I replaced it with a Mallory distributor and didn't care for it either, although at least it didnt self destruct. I eventually put the OEM distributor back in the motor because it worked the best and was the most reliable.
Old Dec 28, 2006 | 07:08 AM
rubyred93's Avatar
rubyred93
Have nothing positive to say about the OEM Opti's. Replaced mine along with the waterpump, plugs and wires 3k miles ago and it just recently crapped out on me....again.
I've done some research and will be going with the DynaSpark this time.
